Front "Y" with no cats question?
Old Nov 27, 2005 | 08:17 AM
CG77VETTE's Avatar
CG77VETTE
Default Front "Y" with no cats question?
I'm picking up one of these for my '86 iron head. My questions are as follows:
1.) Does it have an opening for the stock oxygen sensor?
2.) Am I going to throw any codes by eliminating the pre-cats?
3.) Are there any smog issues I will need to deal with?
4.) What does "for off road use only" really mean?
I apologize for so many questions and thank you in advance for any help or advice.
Old Nov 27, 2005 | 08:59 AM
eric_daniel's Avatar
eric_daniel
I believe that the "for off road use only is strictly a CYA for the company because running without cats is illegal in most, if not all, states. They wouldn't want to be selling an illegal mod, so they state that it is strictly for racing (on the track) use only. As far as I know, it will not pass smog tests, but I don't know if NJ has those. When I lived in Texas, I had to have smog tests done, but in louisiana I don't. Unless you have a "friendly" inspector, you probably won't pass any inspection with or without smog tests. I have muffler eliminators on my car, but I have a friend that does inspections. As for the codes, I have no clue....
Old Nov 27, 2005 | 09:09 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I had an exhaust shop cut the pre cats out and weld in new pipe. Half an hour later i was on my way without one scratch or knuckle torn off
No issues
Old Nov 27, 2005 | 09:14 AM
bogus's Avatar
bogus
well... as for passing smog... precats won't effect the result one bit. what will effect it is the quality of the main cat.
Codes... none...
visual inspection? FAILED. If NJ requires them, then you are hosed.
Old Nov 27, 2005 | 09:18 AM
MBDiagMan's Avatar
MBDiagMan
On an '86 you won't throw a code. There is only one O2 sensor. On later models, certainly beginning in '96 if not earlier, there are O2 sensors before and after the cat that monitor the temp sensor. On those cars removing a cat would CERTAINLY result in a trouble code.
On my autocross car, an 88, I have NO cats and it doesn't throw a code.
I fully expect that the Y pipe you buy with no precats indeed has a bung for the O2 sensor.
Hope this helps,
Old Nov 27, 2005 | 09:57 AM
CG77VETTE's Avatar
CG77VETTE
Codes... none...
I will also be replacing the main cat with a brand new high flow converter which dumps into a Magnaflow catback system which should be smog compliant. As far as visual, would a state inspector even know that the car came with pre-cats from the factory? Thanks to all for the replies
Old Nov 27, 2005 | 10:03 AM
bogus's Avatar
bogus
Hope this helps,
The 2 O2s on an OBDII car do not work temp, they are testing the effectivness of the cat itself.
Old Nov 27, 2005 | 10:04 AM
bogus's Avatar
bogus
I would expect him to know. however, the bigger question is does he care?
If the sniffer passes, then does it truely matter?
In CA, they are uber-**** about these things...
oh, and get a new 3-way cat.
If it was me, and you could do it, I would get 2 bullet cats, one on each manifold, an x-pipe and true duals from there. You would pick up 25+hp, easy.
Old Nov 27, 2005 | 01:34 PM
vader86's Avatar
vader86
1. It should, I havent seen one that doesnt. If it doesnt, you'll have to order a O2 bung and have it welded in. Summit sells them.
2. No.
3. It will pass a sniffer-only test. The main cat is the one doing most of the work.
4. It has no CARB #. You'll fail a visual and its technically illegal to alter OE smog equipment. If NJ has no visual, dont worry about it.
Old Nov 27, 2005 | 02:53 PM
MBDiagMan's Avatar
MBDiagMan
I have no idea what you mean by "work temp."
What the two O2 sensors do is measure the temperature before and after the cat and are looking for at least 100 degrees difference. If the 100 degrees difference is present, this is taken as an indication that the cat is indeed doing its job. This is very basic and is even a question on the ASE tests.
Have a great day,
Old Nov 27, 2005 | 03:12 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
I couldnt even get my Borla's welded here in California last year because at the time I wasnt running precats So they refused to work on my car
As far as throwing codes..you won't.
I, at a point in time, was running no precats and a gutted cat and had no codes. The car was pretty freakin loud, cant imagine what headers and true duals sound like Im back to stock cats now
Old Nov 28, 2005 | 12:11 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My 86 iron head is running a factory 85 front Y. The O2 sensor location is a perfect match. No codes. Only smog issues is you won't pass the visual inspection. As for Q3, how can it be explained any clearer? You can't drive on the streets and highways.
Since the precats are only effective during the first start/warmup period, their absence is not easily detectable at a smog station. Simply cut off the precat chamber shells from your old pipe and welding them onto the catless pipe. Now you'll pass visual
Old Nov 28, 2005 | 01:37 PM
CG77VETTE's Avatar
CG77VETTE
I'm assuming the '85 front "Y" that you are running has no precats which is exactly the same pipe I'm buying. Part of the sales ad states "for offroad use only" which was the reason for my question. Does this mean you don't drive on the streets or highways with your car since you are running exactly what I will be running?
Old Nov 28, 2005 | 02:29 PM
vader86's Avatar
vader86
it means what we've told you, they put that phrase in there because its illegal to change the factory emissions system, meaning youre not supposed to drive the car on the street with this pipe because you've altered the factory emissions system by deleting the precats.
i imagine he runs his car everywhere that everyone else on the forum does
if you want to pass a strict visual, dont put the thing on there, its that simple. Otherwise, dont worry about semantics.
Old Nov 28, 2005 | 03:49 PM
Rick86's Avatar
Rick86
I got my front cat-less Y and main cat from Ecklers and it was advertised as 49 State Legal. The place in California I ordered from only ordered them for me because my car was still registered in TN, but I have had it smogged twice now here in CA with the cat-less Y and have not had any issues. I believe the ad stated it was only 49 State legal if used with their 3-way main cat. Hope this helps.
Old Nov 28, 2005 | 04:47 PM
JrRifleCoach
Nope! If a sharp Smog tech does the visual 100%, you'll fail without the precats. Although using the correct main cat WILL PASS the sniffer test. We are not authorized to alter the OEM configuration.
Sad, that we can make our engines produce more power and less smog.
Oh well! I can pass a drive by sniffer now! Thats all that matters.
Old Nov 29, 2005 | 03:33 PM
TA's Avatar
TA
I have one sitting in my garage you can have for $50 if you come pick it up. I sent you a PM.
Old Nov 29, 2005 | 07:41 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Yep,its true.You get a registration card with the system showing its legal in 49 states.I did this on my 86 when I lived in NY and passed Inspections with no problems.
Good Luck!
Old Nov 30, 2005 | 06:28 PM
Rick86's Avatar
Rick86
Because my car was originally a 49 state car it only has to meet Federal standards when tested in CA. That might be why I have not been questioned about the 49 State legal front Y-pipe.
To Front "Y" with no cats question?
