87 electronic air lights blink?
Old Nov 28, 2005 | 11:19 AM
shawn 84&92's Avatar
shawn 84&92
Default 87 electronic air lights blink?
the lights on my friends 87 with electronic air blink when he hits a bump. the climate control works, but the lights blink. Could this be a ground or the control unit?
thanks,
Shawn
Old Nov 28, 2005 | 01:18 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Sounds like a ground issue, 1st thing to check
Old Nov 28, 2005 | 03:13 PM
shawn 84&92
anyone know where the grounds are located?
Thanks,
Shawn
Old Nov 29, 2005 | 10:15 AM
rick lambert's Avatar
rick lambert
I had the same problem with my 87, I pulled the connections and cleaned them and it cured it for quite awhile-guess I have to do it again.The unit itself if I remember correctly is a sealed unit-but if memory serves me right, someone here said there is a little round area on the back of the unit that needs to be resoldered for the ground-don't hold me to this cause I just vaguely remember.
Old Nov 29, 2005 | 03:36 PM
JAKE's Avatar
JAKE
I used a pencil eraser to clean the contacts when mine was doing the same thing. All it took.
Jake
Old Nov 29, 2005 | 03:46 PM
SunCr's Avatar
SunCr
If it isn't the contacts, ground runs to the the driver's side kick panel area. It has it's own lug which sits on top of another lug that contains most of the forward interior grounds. Remove driver's hush panel to access. Then look on the left kick panel, near the support, for the ground.
To 87 electronic air lights blink?
