chassis lubing
Old Nov 29, 2005 | 08:15 AM
helopilot's Avatar
helopilot
Default chassis lubing
I've got a basic maintenance question regarding lubing the ball joints and tie rod ends on my '85. How much grease do you pump in the ball joints and tie rod ends? I've searched the GM shop manual and forum but haven't found a good answer yet. Also, is there a better grease than the GM spec'd grease in the shop manual to use? I've lubed my other "traditional" cars before but the C4 is far from "traditional" vehicles in a lot of ways and I just want to verify so I don't screw it up. Thanks for the help!
Old Nov 29, 2005 | 09:14 AM
nutz4c4's Avatar
nutz4c4
My $ .02... You want to watch the rubber boots when they begin to bulge that should be enough grease. I have been using Mobil 1 synthetic grease for a couple of years now and IMHO it stands up better to water invasion and the elements in general. Use it on all my vehicles including boat trailer wheel bearings .
Old Nov 29, 2005 | 10:34 AM
Slalom4me's Avatar
Slalom4me
The key is to add a small amount on a regular basis.
I use a pistol grip lube gun and squeeze the grip
part of one compression - enough to know that grease
entered the fitting.
Once the grease migrates out from between the
friction surfaces into the surrounding pocket formed
by the boot, there is less likelyhood that it will provide
lubrication.
If the integrity of the boot is compromised so that
water and abrasives can enter then joint life is
shortened.
Old Nov 29, 2005 | 11:28 AM
rws.1's Avatar
rws.1
I understand that most C4 have my problem... someone overfilled the boot in the past...
Supposed 3 pumps with a grease gun is the max that should be used
How do I change the boot?
Old Nov 29, 2005 | 01:19 PM
helopilot's Avatar
helopilot
Thanks for your replies, guys. I know chassis lubing isn't the most exciting thing to discuss but sometimes ya just gotta ask!
Old Nov 29, 2005 | 03:45 PM
Slalom4me's Avatar
Slalom4me
Originally Posted by rws.1
Suppose 3 pumps with a grease gun is the max that
should be used?
As an experiment, visit a local shop and see if they
will give you an old t-rod or b-joint. Cut off the seal
and then see how much grease escapes past the wear
surfaces when you apply 3 pumps.
I think that if there was already grease from the
nipple, through the passageway to the wear area, then
you will see a noticable amount of surplus grease.
But YMMV.
Remove the rod end or ball joint - assuming that
boots are available separately. I know they are for
other vehicles but can not say for the C4.
Frankly, if it were mine, I'd probably leave it in place
to live out its possibly shortened life and then replace
the complete assembly. The grease in the boot helps
as a seal, periodic shots keep the working area happy.
Old Nov 29, 2005 | 03:52 PM
Slalom4me's Avatar
Slalom4me
No need for apologies, more questions like this please.
Then maybe I won't hear the pneumatic grease gun
at the Quickie Lube droning on with its ka-chunka,
chunka, chunka as the operator moves from fitting
to fitting on cars in the neighboring bays.
There's a reason why they stopped providing nipples
on a lot of moving components.
Old Nov 29, 2005 | 03:58 PM
SJW's Avatar
SJW
This points up yet another reason why I never let anyone else do lube/oil/filter jobs on my vehicles. Those clowns almost always blow out the boots when they pump grease into a joint.
Re: how much to add:
You want the boots to be holding some grease, but not overfilled to the point where they are in danger of rupture. If the boot is already looking full of lube, leave the joint alone!!! If the boot has begun to shrink down indicating it can hold some more lube safely, then pump only as much in as is required to get the boot to start to fill out again. Use a pistol-grip, manual grease gun. Pneumatic grease guns oughta be outlawed!!!
Be well,
SJW
To chassis lubing
