Bogs/runs lean (?) at altitude 89 A4
Old Dec 2, 2005 | 02:39 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
So are you going to load all your plaster and chemicals and pool cleaning equipment into the back of the z? Throw a tarp down, it'll be fine.
You should swap your 89 with the z, keep it at the carport.
Old Dec 2, 2005 | 03:12 AM
cv67's Avatar
cv67
St. Jude Donor '05
I think if I took the hatch off I could even mount the 500 lb, compressor in there, too. THis might work
Old Dec 2, 2005 | 06:06 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
... waiting for someone to ask if the compressor can be used as a supercharger
Old Dec 2, 2005 | 08:41 PM
cv67's Avatar
cv67
St. Jude Donor '05
Gets a code 42. (I may not have cleared it from the last time I got a code, was either 42 or 43)I remember it was the EST code, distributor was in a tooth off.
What is code 42?
When I ground the two pins to pull codes, the fan come on. Also noticed the fan comes on at 110 degrees, sometimes within a minute of startup. Stock chip, hypertech 160 fan switch, new CTS.
Oh yeah, coolant in overflow tank has oil all over the top of it, radiator coolant which i just replaced looks like cr4p, but see no water/milkshake on dipstick or oil fill area.
Old Dec 2, 2005 | 08:43 PM
CFI-EFI's Avatar
CFI-EFI
Prove me wrong.
A negative can't be proved.
But I guess since your car runs faster with higher DA... Maybe it'd be even faster if you added some weight too.
Who said anything about a higher DA? Are you *** YOU ME ing, again?
RACE ON!!!
Old Dec 2, 2005 | 09:34 PM
CentralCoaster
Originally Posted by CFI-EFI
cuisinartvette,
Problems at altitude? What altitude? I went a half second faster, at LACR.
Yeah, I *** ZOOMED from the above statement that you were claiming your car was somehow immune to increasing altitude. What am I, a mind reader? If you don't want to be misread, don't post misleading/incomplete/ out-of-context statements.
I think you want people to misread you, merely so you can jibberjabber about how incorrect they are.
Old Dec 2, 2005 | 10:34 PM
CFI-EFI's Avatar
CFI-EFI
Increasing altitude? Who said anything about INCREASING altitude? I even poo pooed the altitude by saying "Problems at altitude? What altitude?"
It takes a pretty weak mind to blame the motives of the speaker for the inability to understand the message. I'm sorry if you have trouble keeping up with me.
RACE ON!!!
Old Dec 2, 2005 | 10:52 PM
Z51L9889's Avatar
Z51L9889
What is code 42?
Code 42 is the EST circuit.
Old Dec 3, 2005 | 12:39 AM
CentralCoaster
RACE ON!!!
And it only takes one finger to tell you to **** off.
JIBBERJABBER ON!!! you miserable old man.
Old Dec 3, 2005 | 02:05 AM
hippy's Avatar
hippy
Cusinvette, since this post has now turned into a pissing match, what does your coolant look like? Is it BROWN and POOEY looking? Does it look like chucks of crap are in your radiator? If so my GUESS and it's only a fking guess is you may have an intake gasket out. PM me and we can discuss it.
Old Dec 3, 2005 | 02:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
PM sent
Old Dec 3, 2005 | 02:30 AM
hippy's Avatar
hippy
PM sent
Roger, sent back, hot potato(e).
Old Dec 3, 2005 | 04:15 AM
  #33
CentralCoaster
A good way to check for that is to drain a cup of oil out into a clear dry container and check for water. Water will settle to the bottom after the motor sits awhile. There really isnt any oil pressure up by the coolant ports to the intake, but I'm sure itd find its way in anyways to give you a residue.
Old Dec 4, 2005 | 03:14 AM
  #34
BrianCunningham
That's normal, it's so the engine doesn't overheat during diagnostics.
I remember you buying an book on TPI systems when we were over PAW. If so there's a real good diagnostics section in there.
