Changing rear gears
Old Dec 1, 2005 | 12:21 PM
rad928music's Avatar
rad928music
Default Changing rear gears
I have 1986 vette with the stock gears in back and would like to upgrade to a 3.73, has anyone done this and how much did it cost to have it done at the shop?
Old Dec 1, 2005 | 12:35 PM
vader86's Avatar
vader86
In an automatic? I'd advise against it. L98 requires nothing lower than 3.07.
Even if you change the intake to Superram.
You'll lose what top end you have.
Old Dec 1, 2005 | 05:08 PM
Biff Buyer's Avatar
Biff Buyer
i am curious as well
Old Dec 1, 2005 | 05:22 PM
rlane5's Avatar
rlane5
what if your car has decent ported heads with a Hot Cam and go through the traps (1/4) at 4500 rpm, could it use more gear than 3.07?
Randy
Old Dec 1, 2005 | 05:26 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I have an 86 with 3.33 and it had great 60' times and would just humm after the 1/8 miles.
No more power.
Old Dec 1, 2005 | 05:53 PM
vader86's Avatar
vader86
Randy
The cam and heads would call for a bit more gear, but its the TPI intake thats still going to limit the combination. So no, you wouldnt benefit from changing gears.
Old Dec 1, 2005 | 07:17 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
Randy
if you're going through the traps at 4500 in your drive gear, and i am assuming this is a l98 motor, then you are right there. no more gear required.
Old Dec 1, 2005 | 07:35 PM
rlane5's Avatar
rlane5
Rider,
The car can rev to 6500 rpm LT1 conversion with heads and hot cam
Randy
Old Dec 1, 2005 | 08:03 PM
vader86's Avatar
vader86
Rider,
Randy
And at that point, we're talking about a different engine and not an L98 anymore.
Old Dec 1, 2005 | 08:33 PM
joe3906's Avatar
joe3906
Old Dec 1, 2005 | 08:34 PM
DocSpeed's Avatar
DocSpeed
Old Dec 2, 2005 | 08:55 PM
mrgrimes's Avatar
mrgrimes
I put a Richmond 3.73 in my Dana 44, but have not built the motor yet. It will not be stock or a TPI but some thing else that revs. It took me along time to get it right, and every time you take it apart to redo all the adjustments on the pinion, ring gear, and every thing else you run the risk of damaging parts. I would definitely not recommend that you do this unless you have been turning wrenches all your life. You can get them for about $1500 + core charge. I spent about $400 in parts and tools (I made most of my own tools to do it). If I had to buy the GM tools I probably would have spent more than $1500
To Changing rear gears
