Brakes
Old Dec 1, 2005 | 03:55 PM
valkryder's Avatar
valkryder
Default Brakes
I'm no mechanic by any stretch of the imagination. But last week my brother-in-law and I changed the front brake pads on my '84. I drove it for about a week and yesterday out of the blue I got a screeching noise on the driver side. This is not happening all of the time. Which, I know makes it harder to diagnose. When I installed the pads I noticed that they had a sensor tab. I installed them as indicated with the sensor on the inside. I'll be pulling the wheels on Saturday. Anything special I can look for?
Any comments or ideas?
Old Dec 1, 2005 | 04:17 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
was it a screech or a clunk? check those new pads for looseness while still in the caliper on the rotor. if they can move, pull them.
Old Dec 1, 2005 | 05:47 PM
valkryder's Avatar
valkryder
It's a screech not a clunk.
Old Dec 1, 2005 | 09:44 PM
1stC3Vette's Avatar
1stC3Vette
I have always used the blue colored anti squeak that you would place on the back side of the pad. The screeching is most likely the pad vibrating against the caliper.
Good luck,
Dino
Old Dec 2, 2005 | 04:28 PM
valkryder's Avatar
valkryder
Are you pulling my leg or what? You know it's quite long by now. I have never heard of blue anti-squeek. If I go in to NAPA are they going to laugh me out of the place?
Old Dec 2, 2005 | 04:33 PM
USAsOnlyWay's Avatar
USAsOnlyWay
No it's real.
Old Dec 2, 2005 | 05:55 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Where did you get your pads and do you know the brand and composition (material)?
Old Dec 2, 2005 | 06:01 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
How did you prep the rotors? Noise is a vibration, and the pads and rotors both contribute.
Old Dec 3, 2005 | 10:25 AM
1stC3Vette's Avatar
1stC3Vette
There are multiple colors if that is what you are concerned about. If it makes you feel better, ask for the Red CRC antisqueak. If they laugh at you, go to a different parts store.
Good luck with your leg,
Dino
Old Dec 6, 2005 | 02:01 PM
valkryder's Avatar
valkryder
Thanks guys. I removed the wheels and brake pads, cleaned the rotors and pads and have had no noise since.
My other problem is a little more perplexing. I can't lock up the wheels. When I try I get to a point where the brake pedal hits a stopping point, rock hard. Do I need to bleed them? Like I said I'm no mechanic.
To Brakes
