Cars is an '85 - This screen capture is from Tunercats $1F file. Can anyone explain what this screen is for? Bin is from a Carroll Supercharging chip. Does it refer to "Air/Fuel Ratio" as in 'reading the O2'??? TIA
Ok, last question: (don't everybody jump in at once and answer this one!)
Question: "Change to Air/Fuel" means 'change to O2' reading or 'change to AFR map' ??? TIA
I take the %change to fuel/air ratio vs. (xx) tables to mean that the ecm will change the Desired/Target fuel air ratio by that % under those conditions. This looks to me like the Only way you can actually change what the Target F/A ratio is in this ECM. You can play with Pulse width, and timing, and etc - but the BLM is still going to work to bring the measured F/A ratio back to the Target.
BTW - the stock GM chip does the same as the Hypertech - carries 0% till 5200 rpm (It's an L-98 for god sake - it's fell on it's face by that high!) then drops the target 3.1% from there up. That's in the "vs. RPM" table.
Thats interesting. My hypertech chip is different than yours. Mine actually dips down to "-3.1". Like a rev-limiter...Weird. The GM bin I just got from the dealer stays at 0 to 6400 rpm. ...1985 vette owners are really a minority here in scan-tune.
