Rear mount turbo?
Old Dec 2, 2005 | 06:45 PM
derck_mullin's Avatar
derck_mullin
Default Rear mount turbo?
Just wondering if anyone has mocked up or considered doing a rear mount turbo system for the cars? Seems to work pretty well in some different applications, namely LT or LS1 F body cars.
Old Dec 2, 2005 | 07:35 PM
mn_vette's Avatar
mn_vette
talk to Bruce
Old Dec 2, 2005 | 07:37 PM
derck_mullin
Sorry...who's Bruce???
Old Dec 3, 2005 | 04:00 AM
Bruce's Avatar
Bruce
do a search under my name. You will find everything you need to know from my old suopercharged combo to the new rear mount turbocharged combo.
Old Dec 3, 2005 | 12:46 PM
derck_mullin
Coooooolll...I'll start lookin.
THX
Old Dec 3, 2005 | 09:06 PM
derck_mullin
Sorry, did the search and maybe did something wrong...can you link me to your setup please???
THX
Old Dec 3, 2005 | 10:07 PM
Bruce's Avatar
Bruce
Here it is.
383LT1
T6 85mm turbo
Water to air intercooler
Here is a pic behind the car
Here is a pic close under the car
3 gallon water tank
Old Dec 3, 2005 | 11:08 PM
derck_mullin
AWESOME...do you have a link with all the mods??
Old Dec 4, 2005 | 12:30 PM
Bruce's Avatar
Bruce
I don't have a link but here is the all mods. Car is a 93. Motor and heads built by Agostino racing Engine in Antario Canada. Turbo is Built by buddy (Baldturbofreak)
383LT1 w/ 9:1 c/r
Garret TV85mm turbo large frame
6 Point Roll Bar
Tial 50mm BOV
42mm Race Waste Gate
6x10 Barrel water to air intercooler
Custom 3 gallon water tank chilled by ac system
4340 Eagle 3.750 stroker crank
4340 Eagle 6" H bean rod
JE Heavy Duty Blower/turbo piston
JE rings
Fully ported&Polished LT1 heads flowed 260/198
Mainley Severe duty valve 1.57 x 2.02 with titainum retainer
Comp Cam double valve spring
Crank gold 1.6rr
58mm BBK TB
Trick flow .08 wall thick one piece chromoly push rod
Cloyes double roller chain
Custom Grind extreme energy cam 222/230 @.05 .565/.605 114+4
Comstic multi layer steel gasket with ARP head studs
7 QT Morroso oil pan with Melling high volume oil pump
Clevitt 77 H series race bearings thru out.
Delteq system
Upgraded 95 Intake and fuel rails
Upgraded 95 timing cover and Opti along with Electric water pump.
Twin 255LPH GSS340M fuel pumps
Aeromotive external regulator
Aeromotive fuel filter
-10AN braided line feed split into two -08AN to both rail
-06 Return.
Innovative LC1 wide band
DFI Gen 7 and 96s injector will be in use in the up coming Spring.
Currently running 50s injector with stock ecm.
To Rear mount turbo?
