header coatings
Old Dec 3, 2005 | 08:10 AM
vstol's Avatar
vstol
Default header coatings
Jet Hot or HPC? I will be using the 1300f coating on my headers any comments or experiences with either one?
Old Dec 3, 2005 | 10:55 PM
RatC4's Avatar
RatC4
Have you heard of Swain Tech?
http://www.swaintech.com/
They have an exhaust coating that is claimed to insulate well enough to be able to put a hand on the header with the engine running.
Old Dec 4, 2005 | 08:40 AM
vstol's Avatar
vstol
I had not heard of them but I went to their site and the coating is white which will not work for me. Thanks
Old Dec 4, 2005 | 09:12 AM
MYCoupe's Avatar
MYCoupe
I've used Jet Hot's ceramic coating (silver) on a couple of headers before and have been pleased with the results. One was a motorcycle exhaust that came out really sweet. You probably can't go wrong with either one as they have both been around for quite a while.
Old Dec 4, 2005 | 02:18 PM
Bruce's Avatar
Bruce
Swain Tech is 15 min away from my house. Their coating is far better than all others coating. I am willing to bet on it. Nascar use their coating for their header and all other components.
My buddy Baldturbofreak have his turbo hot side coated. It is awsome. The coating alone is .015 thick. It is rough almost like sand type coating. It does not for look but for function. You can touch the pipe after the engine is shut off. Fot that reason I am having my turbo pipes coating at Swain tech as well.
Old Dec 4, 2005 | 03:03 PM
Eike's Avatar
Eike
To bad I have ordered my Hookers coated - if only I had known swaintech before ordering ...
Old Jan 20, 2006 | 11:44 PM
vstol's Avatar
vstol
I am going to go with nitroplate and I will let you know how it turns out
Old Jan 21, 2006 | 12:32 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Given the choice between stainless (uncoated) or steel coated which would be better? How about in appearance after 5 years?
Old Jan 21, 2006 | 12:50 AM
steve1ph2's Avatar
steve1ph2
i bought mine uncoated then had them ceramic coated about 2 years ago for about $180. they still look good. i think i saved quite abit buying them uncoated then having them coated.
Old Jan 21, 2006 | 10:29 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
That is very interesting, .015" thick too. And it doesn't cost much more than the standard coatings which are only about .002" thick.
To header coatings
