Got a HP question?
Old Dec 3, 2005 | 05:26 PM
Sonicdragon2001's Avatar
Sonicdragon2001
Default Got a HP question?
I was looking at a 89 with the engine changed and was wondering what kind of power I should expect if I were to purchase this car? This is all the owner could tell me about the engine can anyone let me know a range for hpr and trq. Thank you.
400 30 OVER (406) COMPLETELY REBUILT 2 ½ YEARS AGO. ALL FEL-PRO GASKETS, FLAT-TOP PISTONS, COMP CAMS PART #51-225-4 (.507/.510 LIFT---284/296 ADV. DURATION---240/246 DURATION AT .050--106 CENTERLINE, HYDRAULIC) PERFORMER RPM INTAKE W/ PHENOLIC SPACER, HOLLEY 750 DOUBLE PUMPER RACE PREPPED AND JETTED. COMPLETELY REBUILT 6X HEADS WITH CORRECT COMP-CAMS 995 SPRINGS FOR CAM, COOL NUT ROCKER LOCKS, AND HARDENED PUSHRODS. BRAND NEW OPTIMA DRY CELL BATTERY. B&M 3200 STALL CONVERTER. DUAL PATTERN TURBO 350 TRANS REBUILT SAME TIME AS MOTOR WITH FIRM, NOT NECK SNAPPING SHIFT KIT. REAR END IS A 10 BOLT FACTORY POSI WITH 4.56 GEARS. HAS DRIVE-SHAFT LOOP
Old Dec 3, 2005 | 10:02 PM
VB Black Ice's Avatar
VB Black Ice
Whats the compression ratio, valve sizes, and head make / model (or flow numbers if available). I'll run it on Dyno 2000 if you want.
Old Dec 4, 2005 | 01:58 PM
kpforce1's Avatar
kpforce1
If you don't have accurate flow numbers, all detailed cam info (including mechanical adv/ret), and exhaust type, it will be WAY off.
Old Dec 4, 2005 | 08:06 PM
VB Black Ice
The heads and cam more than anything.
Old Dec 4, 2005 | 09:25 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
No matter what, it oughta' pucker your shorts!
Old Dec 4, 2005 | 10:58 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
You say it has 4:56 gears?...sure sounds like a dedicated 1/8 mile drag car to me...it better redline at 7500 or you might not make it to the traps in the 1/4 mile before you run out of rpm...
To Got a HP question?
