Throttle body rebuilding service?
Old Dec 5, 2005 | 01:55 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Throttle body rebuilding service?
My TB leaks pretty good (bad) and the shaft has some play so the throttle hangs with the butterflies binding barely open. I cleaned out the TB and after removing the crud from the bores, it leaks even more.
Who redoes these with ball bearings, and do you have any personal experience with them.... cost... turnaround time, etc?
Or is it worth the bother over buying a new TB and having no downtime?
Old Dec 5, 2005 | 06:14 AM
Eike's Avatar
Eike
Hi,
perhaps this guy can help you?!
Old Dec 5, 2005 | 08:55 AM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
You might try this guy over on crossfire forum http://www.crossfire.homeip.net/cfte...=display&id=68
Old Dec 5, 2005 | 09:12 AM
okies93's Avatar
okies93
St. Jude Donor 06
Hey CC.. let us know what you end up doing. I have a funny feeling that I am going down the same road...
Old Dec 5, 2005 | 10:01 AM
KENS80V's Avatar
KENS80V
Do a search for "David Koldos". He did mine and many other Forum members throttle bodies. He replaces the bushings with roller bearings. The Ebay guy just installs a resized bushing. You really want the roller bearing....will last much longer. His price converting to 52mm and installing the bearings was in the low/mid $200 range. He also will just install roller bearings on a stock 48mm throttle body but I don't know about the price. His email address is: dkoldos@ameritech.net
Old Dec 5, 2005 | 04:26 PM
VenkmanP's Avatar
VenkmanP
Originally Posted by KENS80V
"David Koldos".
Haven't used him myself, but have read many good reviews over the years.
Old Dec 5, 2005 | 05:54 PM
KENS80V's Avatar
KENS80V
I'm with stupid ????????
Old Dec 6, 2005 | 06:19 PM
LaVidaLoca's Avatar
LaVidaLoca
Had mine done by Dave. Super job. Eliminated the binding and sticking problems from worn guides. Cheaper than new TB and you get bearings that will last. Also helped me get my idle adjusted and stable.
Old Dec 6, 2005 | 06:40 PM
CentralCoaster
Old Dec 7, 2005 | 07:59 AM
Topload's Avatar
Topload
Had David rebuild / rebore my 48mm up to a 52mm - very happy with the results and his service. Good guy to deal with - and quality work. You can't go wrong (and his price was appropriate).
Old Dec 7, 2005 | 08:00 AM
TA's Avatar
TA
To Throttle body rebuilding service?
