Need help te get those bastards in jail
Old Dec 7, 2005 | 04:53 PM
  #41
Nico's Avatar
Nico
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
Originally Posted by Slalom4me
Contacting Gordon Killebrew could provide more information.
I have AEX. Gordon does not accept that.
Old Dec 7, 2005 | 04:56 PM
  #42
Nico's Avatar
Nico
Originally Posted by Mr Mojo
Isn't there a second build sheet tucked away somewhere in the front frame rail?
On my '95, the build sheet is curled up and tucked under the strap that holds the tank in place, on top of the tank.
Please tell me where the front frame rail is. I dont see that name in the book. I relly like to take a look there
Old Dec 7, 2005 | 05:07 PM
  #43
Nico's Avatar
Nico
Originally Posted by SJW
I would hope that the threat of legal action (civil and criminal) would motivate the seller to make you happy and get you to go away quietly. Have you tried to apply any pressure to them using this as leverage?
Do any law enforcement agencies, customs, etc in Spain have any authority to pursue this on your behalf?
I sure hope you can get out from under this quickly, cleanly and with all of your money returned.
Be well,
SJW
I am afraid that the Authoroties just go to get these guys and don give a d... if I get my money back A law suite is than the option what can take more than 3 years, costly (and bad) lawyers etc. And the car goes to the police, I never see it back again. So my only hope is to straighten these guys out to walk at the right side again so they give me the owner ID. Than I need some paper of the owner that clears me and shows that no criminal acts are involved. I do not want to be involved in that. If they are not willing to give me that. I sue them and loose as well.. If I ever sell. I play open card, tell the buyer about it. Than he can see the paper that no criminal act was involved. If he than still wants the car, ok. If not I dont have to part from my car´.
Old Dec 7, 2005 | 05:09 PM
  #44
ittlfly's Avatar
ittlfly
Nico...there is a hidden VIN # also known as a "secondary number" that is placed on the car. This has come about due to all the auto thefts in the states. They have been on all cars mfg. in the USA since the early 70's (as I recall). There are books that tell where the hidden VIN is located. If the locals authorities can't help you locate it,let me know. I have a few "connections" that can supply the location for you.
Old Dec 7, 2005 | 05:16 PM
  #45
SJW's Avatar
SJW
[QUOTE=Shadow1]
On both my 86 and an 87 that I owned there was a second build sheet in the drivers side front frame rail. They were both rolled or crumpled up but when removed were very legible.
Whereabouts in the frame rail did you find these build sheet copies? How did you get to them?
TIA,
Be well,
SJW
Old Dec 7, 2005 | 05:17 PM
  #46
VtVette's Avatar
VtVette
I thought someone here would mention this...
I don't know exactly where it is, it's in a different location on every car and it's a well hidden secret (I own a body shop and have only come across one or two in my experience). This might really help him out.
BTW, here is a shot of my engine number for refrence. How could it be chipped off the block? It's proiximity is so close to the water pump mounting hole. As someone mentioned earlier, maby they ground it off. In that case it's possible it could be raised again.
Old Dec 7, 2005 | 05:23 PM
  #47
Shadow1's Avatar
Shadow1
It's been many years since I removed the build sheets from my cars but I recall they were stuffed in the frame rail, on the drivers side, above the crossmember. You will need to be under the car and look with a flashlight in every available hole in the rail.
If the sheet is there, it may not be real evident as it is now 20+ years old and will most likely be discolored.
If it is there, you will need to be very careful when attempting to remove it as it may have become brittle also due to age.
Remember, it's just a piece of paper however in this case, it could be worth more than gold.
Good luck.
Side note....On my 87', when I retrieved the sheet I found out the car was a COPO car ordered by the CPC Group Engineering Center to be used as a "pilot" car. The sheet had quite a bit of handwritten notes on it. It had been assembled in March of 1986 and was placed on the assembly line with the 86' production cars. The car is long gone but I still have the paperwork tucked away somewhere.
Old Dec 7, 2005 | 05:25 PM
  #48
ittlfly's Avatar
ittlfly
VtVette...you are 100% correct as each car (model and year) has the secondary # in different locations. And this 84 's secondary might very well be the one already mentioned on a previous post on the R/S frame rail in the engine bay. I hope for his sake, it isn't.
Old Dec 7, 2005 | 05:53 PM
  #49
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I found my tank sticker on my 86 by dropping the spare tire cover down and shining a flashlight up inside and seen the sticker on the tank facing the front-top of tank area.
Dont try and pull it off since it can rip into pieces.You wont see the tank sticker from the back license opening or etc.
If you find a sticker there,then take the steps to remove the bumper cover and lower the rear frame rail down to pull the tank to take pictures and etc of it.
Old Dec 7, 2005 | 06:10 PM
  #50
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
TIA,
Be well,
SJW
I didn't find them, someone here found them many years ago, I don't know the actual location.
Old Dec 7, 2005 | 07:00 PM
  #51
CFI-EFI's Avatar
CFI-EFI
Originally Posted by bluealtered
I don't know if this will help or not but you can find the original vins and the options that came with that vin at www.idavette.net, best of luck,...joe
Joe,
I looked at that web site, but I don't see how to check a VIN to see what options it was built with. How can Nico "find the original vin" of his car on a web site? Starting with what info???
RACE ON!!!
Old Dec 7, 2005 | 07:14 PM
  #52
SJW's Avatar
SJW
[QUOTE=Shadow1]It's been many years since I removed the build sheets from my cars but I recall they were stuffed in the frame rail, on the drivers side, above the crossmember. You will need to be under the car and look with a flashlight in every available hole in the rail.
Good luck.
QUOTE]
Thanks a bunch for the tip. I'll have to take a peek and see if I can find one on mine. Hopefully, since my car's only 12 years old, and was a low-miles garage queen 'til I got her, I can find mine and extract it intact.
Be well,
SJW
Old Dec 7, 2005 | 07:15 PM
  #53
Brimis's Avatar
Brimis
What a coincidence, I just read yesterday that the build sheet is stamped to the gas tank. I would hire a lawyer and let him handle it.
Old Dec 8, 2005 | 03:10 AM
  #54
CorvAdel's Avatar
CorvAdel
The build sheet option is a must Nico...I once got it off of my fuel tank without taking the tank out. Jack the rear of the car, remove the sp. wheel and carrier.There is a gap, app. 20mm between the fuel tank and the chassis where the anti-sway bar is located. You can usually see the lower part of the build sheet high up in the gap. I used a long thin knife and pried the sheet off. It has spots of glue on it in about 4 locations. You cannot cut thru this glue as it is very hard and brittle. The sheet will tear around the glue. It is highly unlikely that you will damage the sheet where it has the VIN...but it could happen. I would take the chance, as this is much easier than removing the fuel tank. You can always remove the tank as a last resort if you happen to lose the VIN by doing what I did on my 86 convertible.
If you happen to "lose" the VIN on the top RH corner of the sheet, there are other identifiers...inc. Job Sequence No., the dealer who ordered it, "VDN No" (don't know what this is)..and I'm sure the Corvette factory could help you if you supplied info to them from the sheet.
If you have/can borrow a domestic steaming machine, I would probably treat the part of the sheet that is visible with that to minimise damage.
It would be highly unlikely that previous scum would have bothered to remove the tank and/or the build sheet. Good luck with this..
Old Dec 8, 2005 | 03:30 AM
  #55
Nico's Avatar
Nico
That is good news. When I bring them in court, that really helps to prove that they did falsify the papers. If the car has been stolen, it really puts them in Jail what helps to heal my wounds. And they can´t hurt anybody else nomore. Now there last claim was that during import the car was given the date of import, BS.. I did not tell them wy, I leave that until the moment they hang them selves with nonsense stories in court. Now my min concern is to get the carfax. That may give me some means to back-up my part of the story and perhaps also to findout if no criminal act are involved like theft.
I keep you all posted
Old Dec 8, 2005 | 05:20 AM
  #56
Nico's Avatar
Nico
Originally Posted by Dynabob
Seems to me my C2 had the VIN stamped on a frame rail as well. You needed a mirror to see it. There has to be a VIN somewhere on that car. I hope! Good luck Nico, I know you have been trying to get this car on the road for some time.
Thanks. I have access to an elevator tomorrow, so that will give me time to search from below
Old Dec 8, 2005 | 06:44 AM
  #57
CorvAdel's Avatar
CorvAdel
Nico...an elevator is not necessary and a mirror may not help you.
I have had to find this number too, once before. You need to take the left hand side centre and front inner black guards off. These are the ones directly behind the lh fr. wheel.
On the vertically upright section of the frame you will find the last 6 numbers of the VIN. They will start with the number 5.
You will probably need to clean the frame rail to see them, as there will be much dirt which may hide the numbers....but they will be there.
Hopefully, they will not be the same as on the windshield VIN plate! Good luck..
To Need help te get those bastards in jail
Old Dec 8, 2005 | 08:07 AM
  #58
bluealtered's Avatar
bluealtered
Originally Posted by CFI-EFI
Joe,
RACE ON!!!
Perhaps i didn't state it right, what i was trying to say was that he could find the correct vin numbers for a 84 there and have it for court if needed. I found everything listed on my rpo there as well.
You are correct as to raising the vin # from the frame, even if it has been ground off or welded over, etching will bring it back up, i used to have this done when buiding harleys to make sure i wasn't building a stolen bike. ...joe
Old Dec 8, 2005 | 08:46 AM
  #59
BAT's Avatar
BAT
2026 Corvette of the Year Finalist - Modified
2025 C7 of the Year Winner - Modified
2024 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
2021 C7 of the Year FinalistAX - Modified
Carfax has been run and sent via PM per your request.... good luck. Looks as if it comes back as an '87 and started off in St Petersburg Florida with one owner.
Old Dec 8, 2005 | 08:50 AM
  #60
BAT's Avatar
BAT
I also forwarded a copy of the original to the E-mail address you gave if you need that other than the copy and pasted version in the PM.
