94 Window Adjustment
Old Dec 8, 2005 | 12:06 AM
Dobro's Avatar
Dobro
Cruising
Default 94 Window Adjustment
I was working on adjusting my driver's side window. When I got the panel apart, I noticed the front bolt on the window had a backing plate that was broken off of whatever it attaches to. I don't know where it connects, if it has a stop like in the back for it to slide into? If so, then that is also missing. I can see a spot where it looks like a bolt went into the door panel to hold a bracket or something. The bolt is missing in that spot and no brackets or anything. I hate to pull the other door panel off to see what I've got, because you know and I know that if I take the other one off, it may just open up something else.....
Old Dec 8, 2005 | 01:02 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
That is your front stop/guide. There is a rail it rides on and it has a special nut on the other side of the window that takes a pin wrench.Look in the Helms manual
