Best Mini Starter
Old Dec 8, 2005 | 09:38 PM
artvette's Avatar
artvette
Default Best Mini Starter
Any opinions on a mini starter for a L98 with stock compression for LT header install? Powermaster, CSI, TCI, Tilton, GM Performance, other?
Old Dec 8, 2005 | 09:40 PM
mseven's Avatar
mseven
I think the stock GM is fine
Old Dec 8, 2005 | 09:46 PM
89sleeper's Avatar
89sleeper
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
I had a mini strater on my 89 coupe with a 383 gave me to many problems so I put an OEM 89 starter on have had no problems since
Old Dec 8, 2005 | 09:54 PM
artvette's Avatar
artvette
Is the stock 89 smaller than a 86?
Old Dec 8, 2005 | 10:53 PM
RatC4's Avatar
RatC4
Yes, it's a cute little Nippondenso gear reduction type, a mini starter. Easy to R+R but if the contacts in the solenoid wear out, the solenoid is not available separately. Mine did have 93k on it when it became senile though so it seems to be a solid unit.
Old Dec 8, 2005 | 11:01 PM
artvette's Avatar
artvette
Hmmm. Sounds like a plan Thanks.
Old Dec 9, 2005 | 01:05 AM
vader86's Avatar
vader86
Get the later 88-91 starter, its a ministarter and actually weighs half as much as the 84-87 starter.
It clears headers fine. I got mine from The Last Detail, its listed there as AC, but its actually Denso.
Old Dec 9, 2005 | 12:01 PM
artvette's Avatar
artvette
Ordered one from The Last Detail today. Thanks.
To Best Mini Starter
