I'm sure this has been asked before but here goes anyway. What is the deal with changing a cam on a 93LT 1. I am going to replace the water pump and opti over the winter and was wondering if I can slide out the cam without pulling the engine. I will also be removing and replacing the radiator.
Thanks STL,
That is a great article. I will already have most of the stuff off the front of the engine anyway so I might as well upgrade the cam and opti.
