Cloyes Timing Chain
Old Dec 10, 2005 | 07:32 AM
Juergen's Avatar
Juergen
Default Cloyes Timing Chain
Now i´m using the timing chain set Cloyes 9-9100 for my supercharched 1992 LT1.
I want to upgrade my car to a Generation II Lt1, so i can use the double roller set 9-3151 . Therefore i have to change the cam, distributer, timing cover and i also need a vacuum line to the distributer and another harness connecter to the ECM.
But what´s about the programm in the ECM for the timing? Do i need another programm? Is this easy to change for a programmer?
For which horspower and Nm i can use the 9-9100 set?
Thanks,
Juergen
Old Dec 10, 2005 | 02:16 PM
STL94LT1's Avatar
STL94LT1
No need for a programming change with the opti upgrade.
