Correct pushrods??
Old Dec 11, 2005 | 05:09 AM
The Bus's Avatar
The Bus
Default Correct pushrods??
I'm getting close to installing my new cam. The engine[ ZZ4 crate engine] has less than 1000 miles on it. It had from the factory with roller lifters and I'm adding along with the cam Crane 1.6 roller rockers. Are the push rods OK to use. Iwas told I'll need harden rods. Are the ZZ4 rods considered harden??
Old Dec 11, 2005 | 05:53 AM
rodj's Avatar
rodj
If you are using stock type "self aligning " rockers you don't need guide plates therefore you don't need hardened pushrods.
On the otherhand if using "non self aligning " rockers you need guideplates therefore hardened pushrods on account the pushrods rub against the guideplate.
Old Dec 11, 2005 | 07:02 AM
The Bus's Avatar
The Bus
Thanks. I already have the studs and guide plates installed. Therefore I need different push rods. I'm getting a real education installing this cam. Thanks
Old Dec 11, 2005 | 11:09 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Bus,
You also need to make sure they are the correct length. The Crane rockers may be slightly different. Need to make sure the rocker crosses the mid 2/3's of the valve stem. You can use some tracing paper to see the pattern. But at TDC, the rocker should be above the midpoint of the stem, and at full lift below the midpoint. Getting a pushrod length checker is an inexpensive way of making sure.
Old Dec 12, 2005 | 05:12 AM
The Bus's Avatar
The Bus
Thanks for the info. The more info the better!
Old Dec 12, 2005 | 06:03 AM
rodj's Avatar
rodj
Are they stock guideplates or ones you have installed?
The question remains are they proper guideplates or just the plates installed to aid assembly at the factory.
The ZZ4 uses the "113" Vette head with better (LT4 ) springs.
I personally think thestock ZZ4 plates are not proper guide plates as ZZ4 have self aligning rocker therefore do not use guideplates in the true sense
Old Dec 12, 2005 | 06:33 AM
The Bus's Avatar
The Bus
The guide plates came with the Crane 1.6 roller rockers. Thanks again for the info
Old Dec 12, 2005 | 10:56 AM
Dominic Sorresso
Bus,
DO NOT use guideplates with self aligning rockers. If the Cranes' came with the guideplates then use them.Using guideplates with self aligning rockers may cause binding which is a bad thing.
Old Dec 12, 2005 | 12:49 PM
hz900's Avatar
hz900
Originally Posted by Dominic Sorresso
Bus,
Can anyone elaborate a little more on this process, or have any pics or where the rocker roller needs to be on the valve stem. I need to check this as well on my build.
To Correct pushrods??
