Top speeds capable in 6th?
Old Dec 12, 2005 | 08:35 PM
black_89_vette's Avatar
black_89_vette
Default Top speeds capable in 6th?
At what point do you see any higher speed in 6th gear over 5th?
Is there hp or gear requirements to see faster speeds in 6th?
And, how much more of a strain on the engine would using nitrous in a higher rpm (5500 +) in 5th? Would it be as safe as say using it in 2nd and 3rd?
Old Dec 12, 2005 | 08:43 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Top speed is achieved in 5th.
Old Dec 12, 2005 | 08:45 PM
black_89_vette
Is that the "be all and end all" to the arguement?
That's what I've heard as well but I didn't know it was written in stone.
Old Dec 12, 2005 | 09:19 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
99.9% of the time
Takes gobs of torque to make 6th the right gear for top speed
Old Dec 12, 2005 | 09:20 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Don't forget the aerodynamic factor as well.
I forget the formula, but it takes something like twice the horsepower to go twice the speed or something like that.
Old Dec 12, 2005 | 10:04 PM
aboatguy's Avatar
aboatguy
I think the power increase needed is the cube of the speed. Which is why the top speeds of the LT1, L98 and the Crossfire powered C4s are so close.
You would need a really torquey engine to overcome the overdrive gearing in 6th gear at high speed.
Old Dec 12, 2005 | 10:46 PM
Solofast's Avatar
Solofast
If you geared the car really short you might be able to see a higher top speed in 6th than a stock car would get in 5th. If you knew the drag of the car and knew the power you could calculate the top speed and then gear the car to achieve it. That would likely be pretty close to where the car is now, but since an LT1 has a good bit more power than an L98 it is likely that you could get 5-10 more mph out of an LT1. If an L98 with 250 hp could do 173 then, in theory a 300hp LT1 could do somewhere near 183 if geared right. That would mean that you would have to put in a 5:1 rear gear to get the right gear ratio that would max you out in 6th. Or, you could put in a 3.3:1 and have the right gearing in 5th..... Obviously it is going to be easier to get the right gear to max out top speed if you do it in 5th....
Old Dec 12, 2005 | 10:47 PM
kopbet89c4's Avatar
kopbet89c4
This would help out a lot, but it is a big block. Not sure if it will fit without cutting a lot of stuff out of your C4.
Old Dec 12, 2005 | 10:58 PM
black_89_vette
Is there any comments or answers about the using nitrous in 5th safety factor? Would it just kill the engine or ...?
Old Dec 13, 2005 | 02:04 AM
88BlackZ-51's Avatar
88BlackZ-51
top speed in 5th without a doubt.
Old Dec 13, 2005 | 08:22 AM
Paul Workman's Avatar
Paul Workman
Default Yep!
It follows a "square law" - essentially power has to increase at (approx) the square of the change in speed to overcome air resistance.
And, too w/ your torque statement. As power is the product of rpm and torque, to reach the power levels required to meet the power requirement to overcome air (and rolling) resistance increases, the torque value in the torque(ft#) = hp*5250/rpm formula has to be significant to make the power needed. This is why it is so important to optimize rpm thru gearing at desired speeds for either sustained power/speed, or for quarter mile efforts, as I suspect you are well aware of too.
P.
Old Dec 13, 2005 | 10:58 AM
stormin310's Avatar
stormin310
I slowly accelerated up to 141 in 5th was taching 5k had to shut it down because of traffic....should it be able to red-line 6300?
Old Dec 13, 2005 | 11:04 AM
Baldturbofreak's Avatar
Baldturbofreak
@30 psi. I dunno If id have a set large enough to go beyond the double century mark. we'll see
Old Dec 13, 2005 | 11:08 AM
Deakins's Avatar
Deakins
If the bottom end of the engine is good enough to hit the nitrous in what essentially is a bog then you will be ok. Just remember that in that gear you will be hammering the bottom end. It’s all in the parts you have!
Old Dec 13, 2005 | 11:09 AM
Baldturbofreak
I dont see any reason you couldnt use the squeeeze in 5th. Just don't use it for more then 10-15 sec unless you have coated, forged pistons to avoid heat buildup in the crown.
Also the solenoids don't like being on for very long. I think 30 sec is the limit before damage occurs
Old Dec 13, 2005 | 11:13 AM
Gary K's Avatar
Gary K
...when the overall gearing in 6th puts the engine in an rpm range that allows it to make more power than is required to overcome drag and rolling resistance at a higher speed than 5th gear is capable of going. Ok, that's a little confusing...most likely, with a ZF6, you'll never be running a rear end ratio that is high enough numerically for this to happen. You might do it with 4.56 gears and over 800 hp for example, but it isn't even efficient to gear that way because of the change in gear ratios from 5th to 6th.
Old Dec 14, 2005 | 03:15 PM
No Go's Avatar
No Go
6th gear was designed as a fuel economy gear...which is great as it works as advertised. The drop from .75 5th gear to .50 6th gear is just too great to make it work. If you gear for 6th with a very low ratio...the other 5 gears don't work so well.
I know some ZR1 folks tried to run 4.56's and the like, but still couldn't get the engine into the powerband in 6th to make it work.
Even the infamous Rick Doria was looking for not so high 6th gear ratios to run in his topend Corvette.
~6300 equals 184 MPH in a stock tired/geared LT4...with another 130 horsepower. A stock LT4 will only do 170-175 depending on condition.
stormin310: You should have been 'JUST' shifting into 5th at that speed...fourth is good to ~140 mph.
Using nitrous for topend runs is not unheard of. Visit some of the Bonneville boards...I know it has been used there. I've tempted to do it...then again...loosing an engine at ~200 mph is sure to hurt...
To Top speeds capable in 6th?
Old Dec 14, 2005 | 04:50 PM
kopbet89c4's Avatar
kopbet89c4
That is a mean LT1. You should have no problem pulling through 6th going thru double centuries! Any vids?
Old Dec 14, 2005 | 05:01 PM
SupaVette's Avatar
SupaVette
A friend of mine and I did some high speed runs a while ago for a local magazine. His was a basicly standard ZR1 which topped out in 5th, and when he changed to 6th he just lost speed. On mine (which is 383 S/C'd) I reached 256km/h in 5th (5500 rpm limit at the time) and pulled in 6th up to 304km/h. It is possible to use 6th provided you have the right power, although i wouldn't recommend doing it to often, because i don't think the 6th gear will last too long. Oh yes and my rear is still standard 3.45
Old Dec 14, 2005 | 05:08 PM
88BlackZ-51
for top speed, the 4+3 tranny works amazing.
top gear in the 4+3 is .68.
