how much can they handle
Old Dec 12, 2005 | 10:32 PM
boxvette's Avatar
boxvette
Default how much can they handle
i have an 87 and i was wondering how much power a stock 4 plus 3 tranny handle and a stock rear end
Old Dec 13, 2005 | 01:08 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
The stock rear end is a Dana 44, which can handle quite a bit. The 4+3 is also surprisingly durable, so long as it is maintained. It is generally the O.D. units that break down.
Tough question to answer. If you don't plan on side stepping the clutch at 4000 rpm with a set of slicks and then powershifting 2nd, 3rd, and 4th, they'll hold up ok.
What are your plans for the car?
Old Dec 13, 2005 | 01:41 PM
MBDiagMan's Avatar
MBDiagMan
I am thinkiing along the same lines as byebye. If you shift smoothly and don't slam the transmission around it will handle quite a bit of torque. If you power shift and such as byebye described, it's life will be limited.
Good luck,
Old Dec 13, 2005 | 02:37 PM
kopbet89c4's Avatar
kopbet89c4
Well, they do handle the Callaway TT Corvette's massive power from what I see...
Old Dec 13, 2005 | 03:43 PM
vader86's Avatar
vader86
A 4+3 was used in the Callaway cars of the time, so it can be made to handle the power.
You just need to keep an eye on that OD unit.
Old Dec 14, 2005 | 11:17 AM
boxvette's Avatar
boxvette
i am building a 83 right now then a few months after i drop that in i will be adding a supercharger and running about 7 pounds of boost
Old Dec 14, 2005 | 11:22 AM
GeosFun's Avatar
GeosFun
I'd suggest drive it 'til you break it, then decide if you need something heavier duty. Some people are easy on parts and some are not.
To how much can they handle
