Need help regarding a bolt on my TPI plenum
Old Dec 12, 2005 | 11:26 PM
87vette's Avatar
87vette
Default Need help regarding a bolt on my TPI plenum
I recently repainted my intake and upon reinstallation, all the bolts went in ok.. however the very first top bolt towards the front of the intake on the drivers side just behind the TB will not go in. It goes in but then gets real tight as if its cross threading. I pulled it out and sure enough it seems to be stripping inside just a little bit but not all the way in. Will a thread chaser fix this problem ? I also lost one of my torque bit bolts for the other side of the plenum somewhere in the engine compartment and for the life of me cannot locate it. I was wondering if someone is willing to send me a spare bolt? Since the dealership and everywhere else doesn't carry it around here. Let me know. Thanks in advance.
Old Dec 12, 2005 | 11:57 PM
VtVette's Avatar
VtVette
Hey 87,
Sorry can't help you with a spare bolt but I did have the exact same problem you are having just one week ago. I bead blasted/painted my intake as well. The bolt would start to go in, then get tighter and tighter until I was not comfortable putting any more pressure on it. Upon removing the bolt I found that there was a little residual sand from the sand blasting I didn't get with the blow gun when I blew out the intake. If you had your parts sand blasted make sure there is no sand left in the bolt holes.
If you did not blast your parts I would try a chasing the threads. Just be sure to check each hole to make sure there is no crap in them.
this is the story of how I literally tried to pack sand...
Brian
VTvette
Old Dec 12, 2005 | 11:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
Same here, sometimes I have to start a bunch of them by hand and "push" the plenum into position to line up a few. I assume you are using antiseize.
I had to go to OSH and use a variant of the torx bolt...Still lose them and strip my threads
Old Dec 13, 2005 | 12:00 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Chase it with a M8x1.5 tap. A new bolt will probably just follow the old one and make it worse. Also, it helps to loosen all 7 other bolts to the upper plenum, and start that troublesome one first.
Old Dec 13, 2005 | 12:08 AM
87vette's Avatar
87vette
Thanks guys... however I didnt use any antiseize and didnt sand blast my intake at all. I also loosened the othert bolts up and wiggled it around and they went in fine. Then I forgot to plug something up in the back that I had to remove it and reinstall again. Now this friggin bolt is a nightmare. I need another bolt for the drivers side of the plenum since I lost it. As for the one that is causing a headache.. I will see if I can chase it.
Hey CC didn't you used to make a set of stainless steel bolts in the past if I remember correctly ?
Old Dec 13, 2005 | 12:27 AM
CentralCoaster
Yeah, don't have any left though. You could probably pick up (7) M8x30mm allen bolts at the hardware store though, so they match.
Also, Napa here sells OEM fasteners, all the wierd bolts and crap. Give them a try.
Old Dec 13, 2005 | 06:50 AM
geogolf's Avatar
geogolf
Default plenum bolt
if you give me your address i will send you one just got new slp runners so i have a bunch of spares i asume you want a short one geo
Old Dec 13, 2005 | 07:50 AM
comp's Avatar
comp
Old Dec 13, 2005 | 07:56 AM
87vette's Avatar
87vette
Yup its the short one I need. Thanks for your help! I sent you a PM
Old Dec 13, 2005 | 08:27 AM
RacerX70CC's Avatar
RacerX70CC
I have stainless sets available, PM me or check my site.
Old Dec 13, 2005 | 01:25 PM
jmrl98's Avatar
jmrl98
I agree with Central - loosen the bottom runner bolts, start the top ones, tighten the bottom, then the top, and you should have no problems. After taking the plenum/runners off more times than I can count, this procedure has not let me down.
Old Dec 13, 2005 | 02:32 PM
87vette's Avatar
87vette
I'll keep that in mind.
Old Dec 13, 2005 | 06:54 PM
87vette's Avatar
87vette
I found a chaser for it and it was a M8 x 1.25 tap. It wasn't the one you mentioned. However I loosened the bolts on the top of the plenum and tried wiggling it around a little to help the bolt slide in better. I had to give it a little pressure with a cheater bar. I kept pulling it out and inserting it several times till I was able to get it in all the way with the help of a cheater bar. I know thats not the correct way to do it.. but it seems to have done the trick. I am now in need of 2 torx bolts since one of mine got stripped on the head now and the other is still lost
To Need help regarding a bolt on my TPI plenum
