Cold running HELP!!!
Old Dec 13, 2005 | 05:54 PM
zapp168's Avatar
zapp168
Default Cold running HELP!!!
I have an 86 vette with TPI and for the first 15 minutes after you start it, it cannot be driven. It acts and sounds like it is leaning out. I have 40-45 LBS of fuel preasure already replaced the filter and have done the following:
MAF
MAF relays
BCM
PCM
Had fuel system cleaned with a machine
Full tune up
this system has the nineth injector, does anyone know if that pulses while the car is running cold? Or if it just comes on to start then shuts off?
HELLPPP!!!
Old Dec 13, 2005 | 06:28 PM
ittlfly's Avatar
ittlfly
You didn't say if you checked the CTS. Bad input from the CTS screws with the ECM and will cause symptoms like you are describing on start up.
Old Dec 13, 2005 | 06:34 PM
CFI-EFI's Avatar
CFI-EFI
Exactly what does, "have done the following:" mean? Replaced? Tested? Looked at? ??? What are the BCM and the PCM especially on an '86 car?
MAF
MAF relays
BCM
PCM Thanks
The first thing to do is check for codes that may be set. Trouble shoot and correct all if those. If you still have problems, I would test the ECT sensor.
RACE ON!!!
Old Dec 14, 2005 | 08:15 AM
zapp168's Avatar
zapp168
I replaced the above mentioned items I replaced the car computer with one from a good running car. replaced the MAF Replaced the burn off relay. THe temp sensor according to the scanner is reading fine there are no codes in the computer. The PCM is Powertrain Control Module.
Old Dec 14, 2005 | 09:33 AM
rick lambert's Avatar
rick lambert
Why not try a little injector cleaner.
Old Dec 14, 2005 | 09:57 AM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Does the car run a lot better after the first 15 minutes?
Old Dec 14, 2005 | 07:20 PM
zapp168's Avatar
zapp168
As for the injector cleaner I had it done with a motor vac fuel injection cleaning system for $150.00.
After 15 minutes this car runs PERFECT. Spins the tires, chirps second gear.
When the car is cold you try to step on the gas and it sputters and pops from the intake like it is lean. I mean you cannot move the car without it stalling. Again I plugged in a scanner and can watch the temp and it is reading accurate. That was actually the first thing I checked cause it seemed obvious.
Old Dec 14, 2005 | 09:00 PM
ittlfly's Avatar
ittlfly
Pull the plugs and read them. If its runnig lean they will tell the tale.
Old Dec 14, 2005 | 09:13 PM
mesteffen's Avatar
mesteffen
Could the EGR valve be stuck open? The reason I'm saying this I had a vehicle with the same symptoms and that was the cause.
Old Dec 15, 2005 | 09:49 AM
dlmeyers's Avatar
dlmeyers
Consider hooking up a scanner and check the short and long term fuel trim figures. I'd check to see when the car goes into closed loop. Does the O2 sensor show rapid voltage moves after about 5 minutes?. Have you ever replaced the O2 sensor? How long has the O2 sensor been in service.
Just speculating.
dlmeyers 90 coupe zf6 3 speed shocks
Old Dec 15, 2005 | 10:40 AM
rick lambert
Have you used the Helms to check your cold start valve? there is also a fuse for it. The first step to diagnosis is to attach a fuel pressure gage-then disconnect the distributor 4 way connector-this will disable the other injectors.Engine temp should be below 35C (95F) turn key on for 2 seconds-note gage, crank engine for for 2 seconds while watching the gage (might need help here), if cold start valve is operating properly the gage should drop more than 3 psi.Incidentally, on an 87 the fuse for the cold start is behind warning light display panel-good luck there.Also it is timed to stay on for 8 seconds if operating properly.
Old Dec 17, 2005 | 07:14 PM
zapp168's Avatar
zapp168
I am thinking the problem is in the cold start valve system, I think GM used the nine injector system for like two years. I think there is a thermal timer that maybe is used for that valve? There is an extra sending unit on the front of the intake that I cannot identify (not for gauge or computer) Just not sure how the system works.
There is a fuse box behind there? or just a fuse? The car has a digital dash.
Old Dec 17, 2005 | 08:01 PM
CFI-EFI's Avatar
CFI-EFI
On the front of the manifold, next to the ECT sensor, is the fuel injection (9th injector) cold start switch. A Helms would be a big help, here.
A Powertrain Control Module AND an ECM in an '86???
BCM???
RACE ON!!!
Old Dec 18, 2005 | 12:11 PM
zapp168's Avatar
zapp168
I use PCM and ECM interchangebly, they are both just computers Powertrain control module, Electronic control module, samething really. BCM is body control module. whick controls alot of the electrical controls for the dash and other electronics.
I saw that switch and I am going to move in that direction.
Thanks!!!
Old Dec 18, 2005 | 03:46 PM
CFI-EFI's Avatar
CFI-EFI
I use PCM and ECM interchangebly, they are both just computers Powertrain control module, Electronic control module, samething really...
Then why didn't you call the BCM, a PCM, too? If "they are both just computers" why would GM name them differently? The PCM and the BCM (?) both report to the CCM on cars, so equipped. Your car has no BCM, PCM, or CCM. You have an ECM, PERIOD. I'd like to know more about your replacement of the BCM.
RACE ON!!!
Old Dec 18, 2005 | 08:52 PM
SunCr's Avatar
SunCr
If it isn't the Cold Start Injector or circuit, a scan can at least verify that the IAC is parked somewhere around 160 (before you start it) and not zeroing out. Unfortunately, with Open Loop operation, there will be no info as to whether it's running rich or lean. You might also try starting it with MAF disconnected.
Might suspect the PROM too - particularly with everything you've all ready replaced. A Bulletin and redesign went into the '85 for a similar problem and should have made it into your Vette. To be sure, you could pull the PROM out, check the # and then make sure it was the latest and greatest for your Year. You should be able to get the # out of the Parts Catalog at www.acdelco.com .
Old Jan 4, 2006 | 10:02 PM
zapp168's Avatar
zapp168
FOLLOW UP:
Testing has revealed that injector nine is not working at all. It has been ordered, but of course is back ordered. I tried using a used one, but it was also sitting for a long time yielding the same result.
Thanks to all who responded, I think when the new part comes in, all should be well.
To Cold running HELP!!!
Old Jan 4, 2006 | 10:16 PM
500hp's Avatar
500hp
I thought you can eliminate the 9th injector with no major, adverse affects (like when you install a SuperRam/aftermarket runners)? I would look at the EGR valve or 'slow' oxygen sensor.
Any exhaust mods on this car? Have you run anything other than unleaded fuel through the exhaust (anti-freeze, other chemicals)?
Old Jan 5, 2006 | 11:35 AM
CFI-EFI's Avatar
CFI-EFI
You can, but the prom (at least) has to be reprogrammed to make the 8 remaining injectors provide enough cold engine fuel to make up for the loss of the cold start injector. I'm not sure, but it may require an ECM change. It isn't quite as easy as unplugging it and forgetting it.
RACE ON!!!
Old Jan 5, 2006 | 12:31 PM
Morley's Avatar
Morley
FOLLOW UP:
Did you verify it was the injector itself that was dead and not the thermo-time switch? The switch sits on the front of the intake manifold next to the coolant temp sensor (it is the larger of the 2). If the switch is bad it won't ever turn the injector on. just making sure it was checked.
