Issue now with drivers side window switch
Old Dec 17, 2005 | 01:21 PM
94azvette's Avatar
94azvette
Default Issue now with drivers side window switch
I am now having an issue where the driver side window doesnt operate
is there anythinig i can do to check if its the motor or the switch?
Old Dec 17, 2005 | 03:52 PM
aboatguy's Avatar
aboatguy
is there anythinig i can do to check if its the motor or the switch?Yes, [SIZE=6]
Do you have a manual?
Do you have a multimeter?
For your problem the later will be more useful than the former!
Mike
Old Dec 17, 2005 | 07:16 PM
bogus's Avatar
bogus
more than likely, it's the motor.
Old Dec 17, 2005 | 08:17 PM
aboatguy's Avatar
aboatguy
Often you can get a little more use out of a stuck powerwindow motor if you hold the switch in the direction the window needs to go and then slam the door like you hate it, while holding the switch .
Old Dec 17, 2005 | 11:09 PM
Soggytaco's Avatar
Soggytaco
I have a simalar problem when the window is down it wont go back up. It will go up after I slam the door. How much does a new switch or motor cost?
Old Dec 17, 2005 | 11:27 PM
bogus's Avatar
bogus
if the motor is stuck, the brushes are going bad... it's gonna require a new motor. Expect about $70.00 from Chris May at Superior Chevy - 1.800.728-8267 - tell him you are forum members and that I sent ya.
Old Dec 18, 2005 | 12:29 AM
aboatguy's Avatar
aboatguy
Your motor is failing! Bogus gave good info on where to get a new one.
Mike
Old Dec 18, 2005 | 04:12 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I would buy the motor and the brace with it ,makes life alot easier on a 94.
Old Dec 18, 2005 | 09:47 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Both windows go to the same thermofuse on my 85. If it's the same onn yours, both windows will stop working when this fuse blows. (It should reset itself after it cools though.)
Old Dec 18, 2005 | 10:57 AM
94azvette's Avatar
94azvette
Thanks for the info guys, yes i have a multimeter and no I dont have a manual yet, i know where i can buy one but im surprised none of our member havent put it digital as of yet. none of you though seem to think its the switch should i leave that alone then?
Old Dec 18, 2005 | 06:56 PM
94azvette's Avatar
94azvette
well i tried slamming the tar out of the door and this motor aint going no where fast, so i guess im stuck with my window 3/4 up until i get this motor unless anyone else has a idea besides slamming my door shut
Old Dec 18, 2005 | 07:53 PM
CFI-EFI's Avatar
CFI-EFI
Jump or short the terminals on the switch. If the window works, the switch is bad. If the window still doesn't move, run 12 volts directly to the motor. You don't need a manual to figure THAT out.
RACE ON!!!
Old Dec 18, 2005 | 11:19 PM
94Ad Blue's Avatar
94Ad Blue
Did any rainwater or other moisture get down inside the door before this happened? When moisture gets down inside, "some windows" appear for some strange reason to go down, but not up?!
A simple hair dryer on LOW HEAT with a flattened cone on the end to better direct air down inside the door panel may be used to dry it out from the top. It only takes a few minutes....
Please do NOT ask how I know this....
(Yes, I hope to have this fixed next month when the new interior is installed.)
To Issue now with drivers side window switch
