Power Locks Will Not Unlock
Old Dec 18, 2005 | 08:02 PM
Mike mike's Avatar
Mike mike
Default Power Locks Will Not Unlock
My 88 will lock the doors from driver or pass side but will not open doors. I do not have a diagram to tell me where I should have power in the unlock mode. Can anyone help?
Old Dec 18, 2005 | 08:10 PM
corvette1989bham's Avatar
corvette1989bham
you will need to pull at least the drivers door panel off, you should have 12 volts to both sides of the switch , when you toggle the switch it should ground either side. The problem could be on either of the doors wiring (or under dash as far as that goes) but you best best is to start on the drivers side. Sorry I cant quote wire colors but it should be pretty self evident but I think the main wire is brown.
Old Dec 18, 2005 | 08:48 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Power%20Door%20Locks.pdf
To Power Locks Will Not Unlock
