Tint adhesive removal
Old Dec 19, 2005 | 11:53 AM
obnoxus's Avatar
obnoxus
Default Tint adhesive removal
Pulled the tint off of my new to me 94 and the adhesive is being a PITA.
ANyone know of a quick(er) easier way to remove it.
I was told 000 steelwool,,, but dont thing my rear window defroster would like that.
Anyone have pics of there cars tinted....... I want to redo them, but make it look classy,,, not pimpy.
Looking for what the car looks like with what % tint.
Thanks !!!!!!
Old Dec 19, 2005 | 01:25 PM
87vette's Avatar
87vette
The way I did it before was to spray warm soap water on it and get a razor blade and pull from the corners. Of course I also remembered doing this in warm weather by putting a garbage bag on the windows also to bring up the humidity. After you get it all off then spray, " Sticker Shocker" which is a bumper sticker removal that melts the glue behind stickers or left over residue glue. Then just wipe off. Worked for me but be a little careful when doing the back window.
Old Dec 19, 2005 | 01:29 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
the guys at the tint shops use a solution of ammonia to remove old tint. they also say to never wash your windows that have been tinted with regular glass cleaners as they all have ammonia in them.
Old Dec 19, 2005 | 01:33 PM
runner140*'s Avatar
runner140*
Professionals use Goo in a spray bottle. It doesn't scratch or etch the glass and softens up the adhesive, then use a razor blade. This is what window tinters use.
Old Dec 19, 2005 | 02:17 PM
obnoxus's Avatar
obnoxus
My biggest concern is the hatch,,, as obvioulsy I cant use a razor blade. Ill try the above and see what happens !!!!!!!!
Old Dec 19, 2005 | 02:22 PM
corvette-pilot's Avatar
corvette-pilot
I know Wal-mart sells a solution in a spray bottle just for window tint. I bet it is an ammonia solution too.
Old Dec 19, 2005 | 03:20 PM
85blkZ51's Avatar
85blkZ51
WD-40 works also. Thats what I used on my GTA.
Old Dec 19, 2005 | 03:57 PM
mrc24x's Avatar
mrc24x
I just removed my new to me 88 pimp my ride special tint from my car also. I removed the hatch and sprayed paint stripper on the tint and let it sit overnight then I used a plastic spatchula (spelling??) to hep lift it off. A PITA since it was old and brittle but it looks 100% better and didn't hurt the defroster at all.
Old Dec 19, 2005 | 05:22 PM
Cashmo's Avatar
Cashmo
3M adhesive remover works well. It's available at automotive paint stores.
Jeff
Old Dec 19, 2005 | 07:12 PM
okies93's Avatar
okies93
St. Jude Donor 06
Jeff
Good stuff.
Becareful with the blades, don't wanna scratch the glass
Not sure of the tint %, rear glass is darker then the sides. I can see real good and hasn't been a problem at night
Old Dec 19, 2005 | 07:28 PM
bogus's Avatar
bogus
A very good friend runs a tint shop in Central FL. He uses a mixture of Dawn dish soap, ammonia and 0000 wire wool. The wool WILL NOT hurt as long as everything is kept wet.
Also, some of the modern tints to not require special cleaning, they are resistant to the ammonia based cleaners.
Old Dec 19, 2005 | 09:20 PM
obnoxus's Avatar
obnoxus
UPDATE !!!!!!!!!!!!!
The adhesive laughed at straight ammonia.
I was about to run for the 3m stuff when I remembered I have a 55 galon drum of castrol super clean.
Rubber gloves and a soaked rag and ALOT of towels in the interior and sides of the car to catch drips,,, turned the glue to goo,,, paper towels and wiped right off !!!!!
Okies ,looks good !!!!!! any trouble on the side windows as it meets the weather stripping,looks like it could be hard on tint.
Only my back window was done when I bought the car.
Old Dec 19, 2005 | 09:54 PM
okies93's Avatar
okies93
St. Jude Donor 06
I used clear finger nail polish around the edges of the tint and don't have any problems with tint lifting.
I went to a car show last summer and notice 2 vettes (C4) that had the rear glass tinted and the edges were lifting around the strut area. The following weekend I ran the clear finger nail polish around the edges on the rear hatch. The seal is up against it all the time.
I like looking at different colored cars with different %tints. Some it adds character too.
Old Dec 19, 2005 | 10:31 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Nail polish remover works for me.
Old Dec 20, 2005 | 07:45 AM
85C4fanatic's Avatar
85C4fanatic
Just make sure you're in a well ventilated area. Its the acetone that is in the remover that does the job! Have used it many times.
Old Dec 20, 2005 | 09:41 AM
obnoxus's Avatar
obnoxus
Originally Posted by okies93
Exactally,Im going for the classy look this time,,, and if lighter tint will give me that,,, thats the route I will go.
Mine is white and I dont want to detract from the cars looks as dark tint sometimes does.
Yours is perfect for polo green
Old Dec 20, 2005 | 11:15 PM
Impala Balko's Avatar
Impala Balko
try spraying rubbing alcohol or denatured alcohol on it... let it sit and use a plastic razor blade thing with no pressure to pull the adhesive to a big clump and pull it off spray and wipe off. It may take several steps like this but it will take it off. At my Sign Shop we use alcohol on adhesives and if its real stubborn we have this stuff called Xlene Xlon which is real strong stuff
To Tint adhesive removal
