113 porting ???'s
Old Dec 20, 2005 | 07:40 PM
jack the stripper's Avatar
jack the stripper
Default 113 porting ???'s
can the alum 113's on my vette be ported and polished to flow as well as aftermarket heads?
Old Dec 20, 2005 | 08:18 PM
CFI-EFI's Avatar
CFI-EFI
That depends in how bad the aftermarket heads you are referring to are. The 113 heads can be improved considerably. They cannot be opened to 227 cc intake ports and they can't be converted to be 18° heads. The answer to your question is Yes, they can. And No, they can't.
RACE ON!!!
Old Dec 20, 2005 | 08:25 PM
jack the stripper
can they be the equal to or better than a set of AFR 190's? i know a lot of members have switched to these. to save effort/money or just cuz the 113's arent as good?
Old Dec 20, 2005 | 10:18 PM
vader86's Avatar
vader86
There are flow numbers on my site if you want to look at them, but no, they do not outflow the AFR 195. (190 is no longer made by AFR)
Old Dec 20, 2005 | 10:25 PM
jack the stripper
damn! and a new set of AFR 195's go for how much?
Old Dec 21, 2005 | 10:31 AM
G-Racer's Avatar
G-Racer
Flow numbers are way over rated although important in different applications & for measuring improvement. Your 113's will give you very good power. Bigger is not always better especially on a street machine.
Let me know if I can be of service.
Old Dec 21, 2005 | 11:06 AM
Red Tornado's Avatar
Red Tornado
TPIS in collaboration with AFR offers 187cc sets for L98 and LT1.
with a cam, and complete intake changeout and LT headers on a 350/355cid, these work out great. i wouldn't go larger intake runners than 190cc on a stock block, but thats my semi-informed opinion. as was stated earlier, AFR doesn't offer 190cc anymore (i think they stopped about 2 years ago), you might might a good set used though. otherwise, check into TPIS/AFR at the TPIS site, and give them a call.
i would sell your 113's to recoup some cost. asking price for a pair in very decent shape in the $400-$500 range.
Old Dec 21, 2005 | 02:12 PM
CFI-EFI's Avatar
CFI-EFI
Less than it would cost to port your heads to anywhere near as good. Porting is nearly 100% labor, and time is money. Even if your heads CAN be ported to meet or exceed the AFR 195 heads, doesn't mean it will cost any less than buying the heads.
RACE ON!!!
Old Dec 21, 2005 | 03:16 PM
mseven's Avatar
mseven
That is true, their website states that it is 187 but I bought some through them awhile back and they are saying that AFR is making those heads from the 190 casting. Not cheap though!!
Old Dec 21, 2005 | 07:56 PM
jack the stripper
so what am i looking at for a set of good used 195's? $1000-$1500? tha engine that i am buying from flatline already has ported 113's, but with the SR and long tubes i was just wondering if they would be enough.
Old Dec 21, 2005 | 08:22 PM
mseven's Avatar
mseven
I don't know about used but I am sure you have seen new AFR 's at 1800.+ complete
If flatline already has ported 113's set-up on it, I am not sure I understand why you want to change or spend extra. What was his set-up with the 113's, it is proabaly a good working set-up already/wcam etc..
Old Dec 21, 2005 | 08:23 PM
cv67's Avatar
cv67
St. Jude Donor '05
I kind of skimmed over these posts, but what cam are you running, and are you running headers/upgraded exhaust?
Old Dec 22, 2005 | 09:08 AM
jack the stripper
it has a zz9 cam and i will be running hooker ceramic super comps back to 2 big bullets. pipes will be at least 2.5", maybe even 3. havent decided on which mufflers yet, but 40 series are always good. unless anybody else has another suggestion. TIA
Old Dec 22, 2005 | 09:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
If you are running duals I'd go 2.5", no bigger.
Have you considered the AFR 180 head? They will keep up with a SR and make killer low/mid-lift numbers. About $1300 from Jegs (or was it summit?). Your car would make some sick torque for a 350. With that cam I dont see where it could make full use of the 195 head.
Of course, a well ported 113 head would run very strong also. It wont keep up with the AFR but is still a decent street head. Problem is by the time you've paid for a quality valve job, bigger valves installed and a full port job you've spent almost the same money as the AFR. Dart makes a nice 180 head, I belive Brodix does too.
Old Dec 22, 2005 | 10:02 AM
rick lambert's Avatar
rick lambert
I'd have to ask myself what is it I'm trying to achieve? if it's max power
thoughs heads ain't gonna work-
Old Dec 22, 2005 | 07:56 PM
jack the stripper
im not worried about max hp (as HP is what you buy and TQ is what you drive). i was just wondering whether the ported heads on it would keep up with the engine. thanks for the advice on pipe diameter. is that to keep backpressure? what kind of mufflers should i run? who has what and how do they sound?
Old Dec 22, 2005 | 08:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
Use the 113's if they are already done.
To 113 porting ???'s
Old Dec 23, 2005 | 01:23 AM
Trog's Avatar
Trog
I don't have any flow numbers but here are some results for my work w/ a dremel & die grinder to my 113 heads. I only did minor clean up & port match on the intake side, exhaust I only took off casting marks & then polished them out. Ignore the flywheel on the printout, it is rear wheel readings...
Old Dec 23, 2005 | 09:30 AM
bluealtered's Avatar
bluealtered
This is correct, having heads that flow say... a zillon cfm is great on paper...but if they only do it at 8000 rpm, and you drive at 5500 max, you have wasted your time and money. It's the same with runner size, bigger isn't always better, remember it's just an air pump, everything needs to be matched together to get the best results for your money.
Old Dec 23, 2005 | 10:45 AM
88BlackZ-51's Avatar
88BlackZ-51
my answer is no, the valves are too small.
