Bulb, sensor ?
Old Aug 2, 2001 | 10:42 PM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Default Bulb, sensor ?
Please help me with this:
My engine is an L98
Between cylinders 6 - 8 exist a bulb or sensor ? and is connected to an arness that have another conncetion to the monoblock near to the exhaust tubes
1- What are those snesors or bulbs, oil pressure or temp ?
2.-what , where is the pcv valve ?, do I have one ?
Eduardo
Old Aug 3, 2001 | 12:37 AM
fundriving's Avatar
fundriving
Default Re: Bulb, sensor ? (Eduardo L98 1991)
Eduardo, I think the connector that is between and just below the #6 & 8 spark plugs is the temp sensor for the gage on the instrument panel. As for the PCV valve, it should be on the driver's side valve cover at the front. It should be in a rubber grommet with a rubber hose connected to it.
Old Aug 5, 2001 | 02:42 AM
Eduardo L98 1991
Where is the connector for the oil temp ?
To Bulb, sensor ?
