Hood Emblem?
Old Dec 26, 2005 | 02:39 PM
pipe's Avatar
pipe
Default Hood Emblem?
How does the hood emblem come off on my 90 I got a new one for Xmas and the prongs on the back of it are not threaded. Are there just clips on the backside? Do ya just pry it off carefully? TELL ME THANKS GUYS Pipe
Old Dec 26, 2005 | 02:54 PM
bogus's Avatar
bogus
if the emblem is like my 92, it was bolted on... from the inside. 2x10mm bolts.
however, they are also held on by sticky tape.
Use some dental floss to cut the glue off then remove all residue. then put the new emblem on.
Old Dec 26, 2005 | 03:02 PM
CooterCatchinVette's Avatar
CooterCatchinVette
Once again bogus knows just what to say!
Old Dec 26, 2005 | 03:03 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Yep, they're right up in there. Might wanna use some peanut butter in your socket. Seriously though, you may want to put a reversed wad of sticky tape in your socket because if the nut falls out of it before you pull the socket out of the hole, it's lost inside your hood forever.
Old Dec 26, 2005 | 03:49 PM
SDS Photography's Avatar
SDS Photography
i am in the same boat right now
i cannot find anything to grab that damn bolt
but i also do not understand what the bolt grabs onto as my new emblem is not threaded
mine is a 89'
Old Dec 26, 2005 | 03:53 PM
SDS Photography
i found this
http://www.corvettefever.com/howto/c...badge_install/
back to it i guess
Old Dec 26, 2005 | 03:55 PM
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
mine is a 89'
Try a deep 10mm socket to remove the nut. When reinstalling, the nut will cut it's own threads into the prong of the new emblem
Old Dec 26, 2005 | 04:13 PM
SDS Photography
got the old one off only to find that I only had one bolt to begin with
and then to lose the one that was holding it on
Old Dec 26, 2005 | 04:14 PM
Redeasysport's Avatar
Redeasysport
If it has been replaced the new ones come with the 2 sided black sticky tape.Might be why you did not see any bolts.Heat it and pry it off if this is the case.If you want to screw them on you an get the plastic nuts at a hardware store.They are for screwing onto unthreaded plastic posts.They look sorta look like a nut made from pressed sheet metal the local part store should have them too.
Duh look at the back emblem.They are basically the same except for the bend on the front.
Use a deepwell socket with a very light touch to remove the nuts as they will strip very easily.You have to allow them to ease up from the plastic posts.In fact use a screwdriver handle with a socket on it.
Old Dec 26, 2005 | 04:39 PM
85C4fanatic's Avatar
85C4fanatic
http://forums.corvetteforum.com/show...m_id=48&arch=1
Here is what I did and where I got the nuts from.
Old Dec 26, 2005 | 05:00 PM
SDS Photography
09-20-2005, 11:21 AM damn
guess those pics are really hard to get uploaded
Old Dec 26, 2005 | 09:04 PM
Brimis's Avatar
Brimis
Bingo! The emblems are not threaded, nor is the emblem sold with the 2 10 MM nuts. You need to buy the nuts and as you tighten the nuts you will "cut in" the new threads.
Old Dec 26, 2005 | 10:14 PM
skybolt31's Avatar
skybolt31
Mine had been removed before I owned the car when it was repainted, when I put the new ones on, I got some "speednuts" and used the stickyback. I think I got the nuts at Advance auto parts. As someone said, use something sticky in your deep socket or it is easy to loose them inside the hood. I dropped one, but retrieved it with a magnet I believe.
Old Dec 26, 2005 | 10:25 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
[QUOTE=skateparkdave]Yep, they're right up in there. Might wanna use some peanut butter in your socket. Seriously though, you may want to put a reversed wad of sticky tape in your socket because if the nut falls out of it before you pull the socket out of the hole, it's lost inside your hood forever.
QUOTE]
I lost one of mine - I used a flexible shaft with a magnetic pickup on the end to fish the lost nut out from the inner hood lining.
Old Dec 26, 2005 | 11:04 PM
pipe's Avatar
pipe
Finally got the emblem off the hood. Had some Vaseline in the socket and didn't lose any of the nuts. Gonna buff that area up then put the new one on. THANKS FOR THE HELP GUYS Pipe
Old Dec 27, 2005 | 04:52 AM
Sam Lam's Avatar
Sam Lam
Removing the nuts is easy with a 10 mm socket. However, removing the socket from the hood recesses with the nut inside the socket is a challenge. Try cutting two strips of electrical tape about 1/8 inch wide. Place each strip diametrically opposite each other inside the socket. When you force the socket (with the tape) over the nut, the tape will hold the nut in place. This is also good to use when installing the nuts. I learned this the hard way!
Old Dec 27, 2005 | 05:10 AM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
if anyone cares those "look pressed nuts" are called speed nuts, you can get a bag of assorted sizes from parts vendors.
Old Dec 27, 2005 | 05:14 AM
The Green Hornet
oops, didn't see skybolt31's reply.
To Hood Emblem?
