AC/Heater Blower fan relay
Old Dec 28, 2005 | 02:59 AM
madmike's Avatar
madmike
Default AC/Heater Blower fan relay
Hey folks, quick question. Where is the Blower fan relay. My manuals show nothing. Blower fan stays on after car is turned off. Id say the relay got stuck. If it even has a relay. It is also stuck on medium blow about #5. Is the relay connected to the climate control module?.1986 VetteL98 by the way. Ive unplugged all the relays under the hood that i could see and its still going. Ive Searched old posts and nothing. Any help would be appreciated. Thanx in advance.
Mike
Old Dec 28, 2005 | 10:09 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It's probably the blower control module. Here's some diagnostics
http://members.shaw.ca/dankai/AC%20Electronic.pdf
Old Dec 28, 2005 | 10:47 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
The fan relay is directly under the blower motor.
Old Dec 28, 2005 | 05:51 PM
madmike's Avatar
madmike
I think it is that module. Kinda pricey. you guys and gals come through again... thanx
Old Dec 28, 2005 | 10:06 PM
SunCr's Avatar
SunCr
Module is used by Electronic Air - about $100. Any dealer should have one since it's used across the GM line - or NAPA has a stocking number. Just make sure the fuse protecting the actual blower voltage back to the Control Panel hasn't opened (assuming you do in fact have Electronic Air), because if it has, you'll get the same symptoms. It's 5 amps and mounted on the firewall. Leads should be whatever color is hot at the Blower Motor - Red/Black some Years; Purple others.
Old Jan 31, 2006 | 01:55 PM
jeffyc's Avatar
jeffyc
MM was it the module, my 91 just started doing that today?
Old Feb 2, 2006 | 03:14 AM
madmike's Avatar
madmike
I actually bypassed the module temporarily. Fan fully on all the time. I got a lifetime fan motor and very easy to change out. Havent had time or funds to get the module. I did have 12 volts continuous into the module through that big red wire in, so I am pretty sure it is the module. Unless anyone know if that big red wire into the module should be hot all the time or on off with the ignition? (1986 electronic air)
Let us know if it was actually is that module. Sorry I didnt follow through.
Old Feb 2, 2006 | 03:17 AM
madmike's Avatar
madmike
well agent 86 schematic just answered that question... haha more than likely the module
Old Feb 2, 2006 | 11:59 AM
slicked25's Avatar
slicked25
And if and when you get a blower module make sure it's the exact same one as in your car because if you don't you'll see heavy smoke in the cabin.
I just order it ac delco part# 15-71642 BLOWER MOTOR CONTROL MODULE $89.34 from discountautoparts.com
Old Feb 3, 2006 | 04:31 PM
jeffyc's Avatar
jeffyc
good price
but mine is a 84mm one
i got one from p&g chevy
$110.40
the dealer here wanted $259.75 before taxes
To AC/Heater Blower fan relay
