Super Ram Question for experts!
Old Dec 28, 2005 | 04:13 AM
Cartier1's Avatar
Cartier1
Default Super Ram Question for experts!
hi everybody!
i have a question about the accel super ram,i have a 91 l98 vette,i'm starting to mod it,but i wnat to know if i have to buy the complete kit around $3370 or the $700 kit part# ACC-74196
also are you guys running with the stock injectors or bigger???if it is the $700 kit
and do i need the manifold lower part ACC-74197 or it fits on the stock one???
is it worth it to upgrade to this manifold??
Thanks a lot!!!!
Old Dec 28, 2005 | 11:38 AM
tjwong's Avatar
tjwong
Originally Posted by Cartier1
hi everybody!
Thanks a lot!!!!
You don't need the complete kit because your fuel rails will be used with the new manifold. The plenum and runners will bolt onto your stock base manifold but to get the full benefit of the SR you should get the lower 74197 as well. You can run the stock injectors as well unless you have a modified 383 or bigger. Then you should consider a larger injector size.
Old Dec 28, 2005 | 03:29 PM
TPI's Avatar
TPI
I agree, get the whole set up. You can find it cheaper on e-bay. I paid $1200 for a new set with base, runners and plenum for my 86. I picked up 2 mph in the quarter with opening the air box, a K&N filter, and removal of the MAF screans. I picked up 5 mph with the addition of the accel super ram. A hypertech chip made no difference compared to the stock chip. The bolts that bolt the plenum to the runners are tedious to install. Get longer bolts with nuts to screw them into. Your 91 doesn"t have a MAF, it's a speed density ecm, and may need to be reprogramed.
Old Dec 28, 2005 | 04:38 PM
Biff Buyer's Avatar
Biff Buyer
would ya need to buy the manifold? Or can you just use the stock
Old Dec 29, 2005 | 01:20 AM
Cartier1's Avatar
Cartier1
Thanks everybody i apreciate your help,nowi know what i need,and seems like the super ram is the way to go!!!
Old Dec 29, 2005 | 01:41 AM
TPI's Avatar
TPI
Larger diameter runners, higher reving, more hp
To Super Ram Question for experts!
