cam swap
Old Dec 30, 2005 | 06:54 PM
pr0zac's Avatar
pr0zac
Default cam swap
can you change the cam with the engine still in the car.. its a 96???????
Old Dec 30, 2005 | 07:08 PM
fredk's Avatar
fredk
Yes you can I just did it. You have to loosen the motor mounts and jack the motor up about 3/4" to clear the crossmember.
Old Dec 30, 2005 | 07:13 PM
pr0zac's Avatar
pr0zac
Thank God!!!!!!!
Old Dec 30, 2005 | 07:27 PM
Dan Parker '96's Avatar
Dan Parker '96
Along with pulling the radiator and creatively positioning the condenser.
Old Dec 30, 2005 | 08:02 PM
pr0zac's Avatar
pr0zac
i figured that much but if you know what it takes to pull the engine you know that its 1000 times easier to not pull the engine.
Old Dec 30, 2005 | 08:07 PM
STL94LT1's Avatar
STL94LT1
It's still not an easy job with the engine in the car. Maybe a bit easier than pulling the engine. Alot of bending over is involved in the swap.
Old Dec 30, 2005 | 08:25 PM
pr0zac's Avatar
pr0zac
anything to do with working on these things require alot of bending over and sometimes involves bending over and taking it up the a$$
Old Dec 30, 2005 | 08:28 PM
STL94LT1's Avatar
STL94LT1
What cam are you going with? specs?
Old Dec 30, 2005 | 08:47 PM
pr0zac's Avatar
pr0zac
well i had just put it together with a cc304 but its now got a bad lobe... i have a hot cam that i was going to use on something else and that is what its going to be replaced with
Old Dec 30, 2005 | 09:48 PM
Dan Parker '96
I originally pulled my engine for a bearing/ring freshening plus the LT1 to LT4/Hotcam conversion. Recently, I tore down the engine (in car) to the shortblock for a Lloyd Elliott LE2 head/cam upgrade (thinking that it'd be less work). That'll be the last time I do that.
Pulling the engine takes the same amount of time and lessens the frustration (massively more productive space for reassembly = less bending and having to worm your appendages into tough spots) provided you have the equipment (lift, stand, etc.).
Both strategies depend on your experience and technique. From now on, I'll be pulling the engine for any major work.
Old Dec 31, 2005 | 12:29 AM
calvette 11's Avatar
calvette 11
Default c-4
It take about the same time.The only problem is the two top bolts
on the bell housing.
Old Jan 1, 2006 | 01:33 AM
Dan Parker '96
Quite true. It's not too bad if you make sure you have clearance on the rear of the engine for the necessary tilt (oil pressure sensor on '96).
You'll also need plenty of extensions and a 14mm universal socket (this has the socket combined with the uni) for the top bolts.
After the first time it's cake.
Old Jan 1, 2006 | 01:43 AM
pr0zac's Avatar
pr0zac
it was way easier than pulling the engine.... i have 6 hours in it and its almost all together.
Old Jan 1, 2006 | 01:49 PM
STL94LT1's Avatar
STL94LT1
6 hours and almost done, I'm impressed. My first cam swap must have taken at least 20 hours, and the second around 12.
Old Jan 1, 2006 | 02:26 PM
tjwong's Avatar
tjwong
6 hours Damn your are hired! It takes me better than 10 hours! And I got all the right tools and a lift!
Old Jan 1, 2006 | 05:42 PM
pr0zac's Avatar
pr0zac
took me 4.5 hours this morning to finish it up and its up and going! runs fing awesome!!!
Old Jan 1, 2006 | 05:58 PM
MikeC4's Avatar
MikeC4
10.5 hours! Dayum...must b the prozac!
To cam swap
Old Jan 1, 2006 | 07:47 PM
Bruce's Avatar
Bruce
LT1/4 cam swaps it takes time from start to finish around 10-12hrs for experience guys. 10-12hrs is using air tools and no lift.
Old Jan 1, 2006 | 09:09 PM
pr0zac's Avatar
pr0zac
that was no air tools and no lift!!! motivation is what is needed.
Old Jan 1, 2006 | 09:30 PM
aboatguy's Avatar
aboatguy
GOOD JOB!
