87 Base timing
Old Jan 1, 2006 | 02:14 PM
robs87vette's Avatar
robs87vette
Default 87 Base timing
Can Someone tell me the Base Timing Procedure or a link for it?
Old Jan 1, 2006 | 02:41 PM
Morley's Avatar
Morley
Start the engine and bring it up to operating temp. Shut it off and disconnectthe EST wire (brown with black stripe) in the engine bay. It is a single wire back near the firewall that coes out of the loom, has a single wire connector on it and disappears back into the loom. With the wire disconnected, start the car with a timing light hooked up and check the timing, should be 6* BTDC. Set it if needed. Shut off the engine and reconnect the EST wire. Pull the fuelpump/ECM fuse by the battery for 30 seconds (clearing the code set from disconnecting the ESC wire). Put the fues back in and you are done.
Old Jan 1, 2006 | 02:48 PM
robs87vette
cool Thanks
Happy New Year
Old Jan 2, 2006 | 09:57 PM
robs87vette
I have yet to find the EST connector, short of tear the car apart I can't see anything back there. Am i looking in the wrong place or might it be inside the harness?
Old Jan 2, 2006 | 10:06 PM
JackDidley's Avatar
JackDidley
Its very near where the throttle cable goes through the firewall. I just sent a pic of the area to someone else on the forum. Send me your email address and I can forward it to you.
Wrightxx@sbcglobal.net
Old Jan 2, 2006 | 10:17 PM
robs87vette
Originally Posted by Spankyellow
Its very near where the speedo cable goes through the firewall. I just sent a pic of the area to someone else on the forum. Send me your email address and I can forward it to you.
Sent! Thanks a million!! Trillion even!
Old Jan 2, 2006 | 10:27 PM
JackDidley's Avatar
JackDidley
Just sent it. Had to send it to Vtvette twice, so let me know if it does not get to you.
Old Jan 3, 2006 | 10:40 PM
robs87vette
I set the base timing today to 6* btdc, TPS to 5.9, then after disconnecting the battery to clear the code the engine idles pretty good on it's own. However the idle is a little irratic and fluctuates mostly between 700 and 800 rpm, occsionally it will dip to like 500 rpm and then surge to about 1000 rpm a couple times, then level out again and do the 7 to 800 thing. Any ideas or suggestions?
Old Jan 3, 2006 | 10:44 PM
robs87vette
maybe I should mention the fuel pressure is about 40 psi, and I was wondering if it could be the gas in the tank? I cleaned the tank out completely when I put in the High Volumn fuel pump and only added 5 gallons at that time. This was back in early spring and I haven't added any since. Did the gas go bad from sitting in the HOT Texas Garage over the summer?
Old Jan 3, 2006 | 10:56 PM
Muffin's Avatar
Muffin
Did you set the IAC as it is supposed to be set?
Old Jan 3, 2006 | 10:57 PM
robs87vette
No I didn't mess with the IAC, but I was wondering if that could be it too? Guess I'll do that this weekend
Old Jan 3, 2006 | 10:59 PM
robs87vette
I say I didn't mess with it but that is a new TB so I did have to take it out of the old one and put it in the new TB, better yet I have a brand new IAC on the workbench so I guess this weekend I'll just replace and adjust it
To 87 Base timing
