help with multi-function lever
Old Jan 1, 2006 | 04:43 PM
drock92's Avatar
drock92
Default help with multi-function lever
I'm trying to get switch asm., pivot and pulse removed. I'mm at the lever now. The manual says to pull toward drivers door. I did that , but still not coming off. I see a c-clip near the steering column, does that need to come off? Also later it says to remove the pin, switch actuator pivot anything special for that. any help would be great.
Thanks, Derek
Old Jan 1, 2006 | 05:31 PM
86PACER's Avatar
86PACER
What year vette?
Old Jan 1, 2006 | 05:45 PM
drock92's Avatar
drock92
sorry, 92 coupe.
Old Jan 2, 2006 | 01:58 PM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
Grasp the lever tightly as close the base as you can. Give it a good strong tug, pulling straight out and it will snap out.
Pulling the switch, pivot and pulse (aka, wiper switch) will require complete column disassembly -- the pin only comes out with the column disassembled. Do you have a GM service manual?
Old Jan 2, 2006 | 02:26 PM
drock92's Avatar
drock92
yep, do have a manual and actually did figure it out yesterday, now just waiting to buy the part tomm. I thought it was the turn signal switch, but I was wrong.
Thanks.
To help with multi-function lever
