front sway bar diameter
Old Jan 1, 2006 | 05:21 PM
PAULEDWARD55's Avatar
PAULEDWARD55
Default front sway bar diameter
Happy New Year out there.
My 1987 has suspension code Z52. I want to replace the front suspension bushings, as my baby has 95k and is 19 years young. I don't race or autocross. How can I determine what the front sway bar diameter ? Any comments from which reputable company I should purchase a replacement kit for all front suspension components?
Thanks,
Paul R.
Old Jan 1, 2006 | 05:28 PM
86PACER's Avatar
86PACER
Simply place the end of an adjustable wrench on the sway bar and tighten. Right by the shock on the fat part is good. Then slide the wrench off without moving the adjuster and measure the jaw opening with a tape measure. That will give you your diameter.
Old Jan 1, 2006 | 05:51 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Should be a 30mm. But measure it to be sure. Sway bar bushings and endlinks are sold seperately from the bushing kit. If you're replacing balljoints and tie rod ends, buy Moog parts from rockauto.com. Don't buy any of the kits from the ecklers catalog, it's all chinese garbage.
As for bushings, I can't give a recommendation there.
Old Jan 1, 2006 | 05:58 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
This should help, too.
Suspension chart
Old Jan 1, 2006 | 05:59 PM
Corvette Kid
Here's another one.
Another suspension chart
Old Jan 1, 2006 | 06:39 PM
c4cruiser's Avatar
c4cruiser
I would recommend polyurethane busings for both the front and rear sway bars and end links but for street use, go with factory-style bushings everywhere else. Poly bushings in the suspension components will stiffen the rid up a bit and may even squeak after awhile.
I would go with factory Bilsteins to get the original ride quality back. Van Steel (a Forum Supporting Vendor) has some decent prices for new Bilsteins. Also check with them on suspension bushings. Also try Vette Brakes for components.
I agree with the use of Moog suspension components. You should be able to find them at NAPA either in stores or their website.
Old Jan 1, 2006 | 06:57 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Originally Posted by CentralCoaster
Should be a 30mm.
For a coupe.
26mm for a convertible.
And that's without going to another web site. Come on NC Kid, keep it on the CF. We don't need no stinkin links.
Old Jan 1, 2006 | 10:18 PM
mrc24x's Avatar
mrc24x
I have an 88 z52 and it came with a 26mm tubular front and 22mm solid rear, should be the same as yours.
Old Jan 1, 2006 | 10:22 PM
Z-07 freak's Avatar
Z-07 freak
Correct for `88, not for `87.
Old Jan 1, 2006 | 10:30 PM
Brimis's Avatar
Brimis
Thanks,
Paul R.
26mm
Old Jan 1, 2006 | 11:50 PM
Corvette Kid
WTF is that?
Old Jan 2, 2006 | 11:08 AM
Red_Vette_93's Avatar
Red_Vette_93
I picked up a set of new bars for my 93: (thanks to C5 Jimmy)
Front is 30mm, solid. Rear is 26mm, solid. Comes with Energy Suspension Front/Rear polyurethane stabilizer bar bushing packages
Can I reuse my endlinks or should I replace them?
Old Jan 2, 2006 | 12:35 PM
Z-07 freak's Avatar
Z-07 freak
Originally Posted by Corvette Kid NC
WTF is that?
Why is it every time someone asks a question, someone else always posts a link to another web site? If you don't know the answer, then STFU. What's the point of the CF if all we are going to do is direct people away from here to other sites???
Old Jan 2, 2006 | 01:09 PM
Red_Vette_93
so I guess we should delete all the links in the C4 FAQ at the top of the page..
Old Jan 2, 2006 | 01:23 PM
Z-07 freak's Avatar
Z-07 freak
...Says the guy whos answer of 30mm solid & 26mm solid is only correct for a `91 Z07. The question was about a `87 Z52.
Old Jan 2, 2006 | 01:24 PM
Corvette Kid
Unbelieveable....
Old Jan 2, 2006 | 02:22 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Hell, I love it if somebody leads me to the info I need..Links or not..That's why I'm here..
To front sway bar diameter
