Costs to Replace Seals?
Old Jan 2, 2006 | 04:59 PM
Shawn93PoloConv's Avatar
Shawn93PoloConv
Default Costs to Replace Seals?
Hey Guys
I noticed a few more oil drops on the floor than normal. I just got the transmission oil replaced so I went back to the place where I got it done. The guy took me under the car and showed me oil on the oil pan and said that my seals were most likely gone. It sounds reasonable considering the age and miles on the clock but I thought I'd check with the experts. My 93 LT1 has about 145,000 miles on it and I drive her every day about 100 miles. How much am I in for to replace the seals?
Thanks!
Old Jan 2, 2006 | 05:41 PM
Jet-Jock's Avatar
Jet-Jock
Before you jump in both feet, have them clean the pan off and remove each bolt put some locktite on them and re-torque. I went through this with my dealer, had the filter, fluid and gasket changed. Had to take it back four times as it kept leaking because the bolts won't stay torqued. It was the first time it had been off since new. So after the fourth time they put locktite on them and they've been fine ever since.
Just a thought...
Old Jan 2, 2006 | 05:55 PM
Bruce's Avatar
Bruce
Most likely will be the seal are bad. This are very commom for LT1 car, the seal cost like $5 and the labor that is hurt. The water pump gotta coming out, the balancer and gotta coming out and the balancer hub gotta come out. That is a lot of work to that job. Dealer probably will nail you for 6+ labor hour for this job.
Old Jan 2, 2006 | 08:30 PM
Shawn93PoloConv
Thanks! I appreciate the tips.
Old Jan 2, 2006 | 08:39 PM
bogus's Avatar
bogus
yea, at this point, it might be easier to remove the engine and replace every single seal... including any transmission seal.
I would also consider replacing the timing chain.
Then the engine will be clean and good to go for a long time!
Old Jan 2, 2006 | 10:24 PM
sonomacrew01's Avatar
sonomacrew01
do what I just did...
took the motor out and replaced every seal.. Head, oil pan, timing, intake etc. I've enjoyed it. I got to add some performance mods, clean the engine and bay and learn alot.
To Costs to Replace Seals?
