Quick question about engine harness routing
Old Jan 2, 2006 | 05:07 PM
VtVette's Avatar
VtVette
Default Quick question about engine harness routing
Hey everyone,
The main front headlight harness comes out of the firewall on the left side of the brake booster behind the battery. From the connector it splits into two individual harnesses, one goes along the frame rail the other behind the engine. My question is does the section of harness that goes to the rear of the engine go over or under the brake booster? I'm thinking it goes over but I want to be sure. The car is a 1986. Unfortunatley there was no harness when I got the car so I am not sure of the routing. Using the helms I've managed to figure out all the other routing but I'm not 100% on this.
Thanks,
Brian
VTvette
Old Jan 2, 2006 | 05:24 PM
JackDidley's Avatar
JackDidley
Email me at Wrightxx@sbcglobal.net and I will go take a pic and send it back to you. I dont have a reliable host so I cant post pics here. Its just under the master cylinder actually.
Old Jan 2, 2006 | 05:36 PM
VtVette's Avatar
VtVette
E-mail sent thanks a lot!
Brian
VTvette
Old Jan 2, 2006 | 05:54 PM
-=Jeff=-'s Avatar
-=Jeff=-
Originally Posted by VtVette
Hey everyone,
Thanks,
Brian
VTvette
Over.. most of the years are the same.. it went over on my 89
Old Jan 2, 2006 | 05:56 PM
JackDidley's Avatar
JackDidley
Pic is sent. Let me know if it did not get to you.
Old Jan 2, 2006 | 05:58 PM
VtVette's Avatar
VtVette
Hey Jeff!
That's what I figured. Also, one other thing I'm trying to figure out where it goes - There is a stud mounted to a plastic mount with two screw holes in the top. There are five or six heavy gauge red wires with fusable links leading to the stud. It must be a power junction block. Could you tell me where it mounts? It *looks* like it mounts behind the battery directly under the hood latch recepticle but again I can't be sure.
thanks again everyone,
Brian
VTvette
Old Jan 2, 2006 | 06:11 PM
nutz4c4's Avatar
nutz4c4
Exactly where that mounts. On the support that runs diagonaly
Old Jan 2, 2006 | 06:21 PM
VtVette's Avatar
VtVette
Thanks everyone, and thanks for the pic Spankyellow!
Brian
VTvette
To Quick question about engine harness routing
