air conditioner question on 87 coupe
Old Aug 3, 2001 | 08:49 PM
corveteer's Avatar
corveteer
Default air conditioner question on 87 coupe
i would like to replace my low pressure cycling switch, located in the return line
from the evaporator. is there a schrader valve behind it ? if i unscrew it
will this open the line and blow out all the freon. it is keeping the compressor
running all the time and and low pressure line sits at 20 psi. high side 225
thanks for your assistance
Old Aug 4, 2001 | 01:13 AM
Togo's Avatar
Togo
Default Re: air conditioner question on 87 coupe (chas stark)
hey chas,
would you do me the favor of emailing me when you get a result to this problem.....mine is doing the same thing, its hell on the motor to keep the coolant temp as high as its getting! if i find out also, i will email you directly!
Old Aug 4, 2001 | 10:22 AM
hi-tek-vette's Avatar
hi-tek-vette
sorry, this isn't what you want to hear .......... yes, you'll blow the charge !! carefull, vision protection needed working on a/c --- i'll look at my car to see if there are service valves, that way you can pump the charge into the compressor/ reciever ...... but, it does'nt sound like you'll be comfortable doing this ....... hey, if you've still got r-12, this is a good time to retrofit the refrigeration ... the current price on r-12 will stun you !
To air conditioner question on 87 coupe
