Valve Spring question
Old Jan 3, 2006 | 03:51 AM
89vettefromhell's Avatar
89vettefromhell
Default Valve Spring question
anyone know the maximum lift on the stock 89 L98 Springs?? im looking at a small cam but the specs are 213/219 duration @ .050 .493"/.502" with 1.6 rocker ... but bearing in mind im on stock rockers aswell not 1.6s... would that fit comfortably? Lingenfelter Cam
Old Jan 3, 2006 | 12:28 PM
89vettefromhell
b u m p
Old Jan 3, 2006 | 02:46 PM
JAKE's Avatar
JAKE
Mt thinking is that since your car is an 89 and IF it still has the stock valve springs, even if they could handle the additional valve lift, they should be replaced.
By now they should be getting pretty tired and I don't believe you'll be able to get the full benefits of the new cam with springs that won't hold up at the higher RPM levels.
Just my thoughts.
Jake
Old Jan 3, 2006 | 04:38 PM
silver & red CE's Avatar
silver & red CE
IMHO, you need better springs than the stock, new or sacked. Don't the LT4 springs, retainers and cups fit the L98 heads?
Old Jan 3, 2006 | 05:08 PM
Ramanstud's Avatar
Ramanstud
Just my thoughts.
Jake
Don't even THINK about re-using those springs. The stockers may survive for a while with those lifts, but they won't perform well and you're asking to break one with the resultant damaging of parts that happens when valves bump into pistons and whatnot.
If you're spending the money for a new cam, seals, fluids, etc - then "spring" for another hundred bucks and get new springs that are applicable for the lifts and RPMs you're going to spin. Call a reputable cam company for their advice.
Old Jan 3, 2006 | 05:33 PM
89vettefromhell
TY TY guys... i should have mention tho that my Springs are STOCk replacements.. only have 5k miles on em... but still id rather replace them as i plan on going with a bigger cam after this next year so i might aswell go with better springs... (im thinking something that can handle 600 lift)
Old Jan 3, 2006 | 05:35 PM
89vettefromhell
now for my next question... whats the stock cam Specs?!?!?
Old Jan 3, 2006 | 07:37 PM
kopbet89c4's Avatar
kopbet89c4
http://www.thirdgen.org/newdesign/tech/mods3.shtml
Scroll to the bottom of the page.
To Valve Spring question
