87 coolant sensors
Old Jan 3, 2006 | 11:04 PM
robs87vette's Avatar
robs87vette
Default 87 coolant sensors
which coolant sensor turns on the main and which turns on the Aux fan.
All of a sudden and main fan only comes on when I install the code reader, coolant temp hit 235 and the main still never came on so I cut the engine off
Old Jan 3, 2006 | 11:17 PM
rodj's Avatar
rodj
More info needed , not clear what your problem is.
Main fan controlled by the computer from input from the sensor at front of the manifold under the TB, will turn on when you jumper the ALDL to read codes.Jumper A +B terminals and the fan should run
Aux fan controlled by sensor between plugs 1 +3 driver side head.
Short thatwire (Green /Blk ?) to earth and the aux fan should run.
"coolant temp hit 235 "
Did the temp get that high or was that just indicated
Old Jan 3, 2006 | 11:32 PM
robs87vette
problem=main fan not comming on in the last 2 days, it was working the other day, when I jumper the a + b on the ALDL it comes on, the Aux fan comes on at 175*
Old Jan 4, 2006 | 09:44 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sounds like the culprit could be the sensor on front of intake or the wiring invoved.
Time to diagnose
http://members.shaw.ca/corvette86/Co...%20Control.pdf
To 87 coolant sensors
