Post header install ????
Old Jan 5, 2006 | 03:33 PM
JEFNLSA's Avatar
JEFNLSA
Originally Posted by Zix
I never got to hear the excessive popping though...I say we disconnect that hose again so I can hear it...
Read between the lines...
Got the ol' SES light on the way to work this a.m. I can't @#$!ing win.
Lookin' forward to findin' out what that's all about.
@#$!er's runnin' great. Why God Why????
btw...Left Merle a detailed message in regards to my ground wire predicament. Hasn't returned my call...yet. hmmmmm?
Old Jan 5, 2006 | 03:41 PM
Nathan Plemons's Avatar
Nathan Plemons
SES could be anything and is likely very trivial.
Old Jan 5, 2006 | 03:47 PM
JEFNLSA's Avatar
JEFNLSA
Probably is BUT I've been suffering in SES h*ll (.02 related) for quite awhile and I thought, w/ the addition of the headers and the offending .02 replaced, I was finally rid of the problem. All I can do is scan & pray. I wanna be emissions ready by July and the SES is my only obstacle.
Old Jan 5, 2006 | 04:13 PM
Zix's Avatar
Zix
Bring it by EM this Saturday to fix the wire and Trevor can pull the code for you to see what's going on. I doubt it's anything to worry about, but I know it's annoying! Or you can always stop by Bills to use his scanner to pull the code if you don't want to wait!
Old Jan 5, 2006 | 08:59 PM
Strick's Avatar
Strick
Originally Posted by JEFNLSA
Update:
Figured out the problem w/ the excessive popping/backfiring after the header install. I'm no expert mechanic so bear w/ me on the explanation. Trevor @ EM made a custom air tube that runs between the two headers. There is a fitting/hose that comes off the tube and runs to the air pump. Somehow the hose wasn't attached and as soon as we re-attached it... BINGO 100% better. Although there still is some mild popping if you let off @ high rpms, the difference is like night & day. Not to mention the car runs 10x better. Trevor & Zix (Jay) explained to me how this could have a big effect on the PCM & fuel mxtures etc... Moral of the story, problem solved. It's like a completely different car. I knew that what I was hearing/feeling was more than what was being described by others w/ headers. Thx for the help...
Jeff
I'm getting ready to finally install my EM long tubes and I want to make sure I understand what they said to you. I still have my AIR system installed and was planning to keep it functional. Are you talking about the AIR connections just off the headers in the engine compartment that also connects to the EGR intake?
Old Jan 5, 2006 | 09:02 PM
Zix's Avatar
Zix
Jeff's car is an LT4 so there is no EGR to worry about. What was accidently left disconnected on his car is the tube that runs from the Air pump to a T-connector by the air fitting on the driver side header. Just an oversight as most of the cars I've seen have the Air pump system turned off in the computer so that t-connector is usually removed.
Old Jan 5, 2006 | 09:20 PM
vettfvr's Avatar
vettfvr
Originally Posted by Lv2xlr8
Same exact thing happened to my car after installing LT's and no cats. The popping went away though after driving for couple days. Now it ony pops when engine is still cold and letting off throttle.
I have EM LT headers with cats and CORSA. I got the popping as well for awhile, only pops when cold and letting off throttle now.
Old Jan 5, 2006 | 09:21 PM
Dan Parker '96's Avatar
Dan Parker '96
Looks like you solved your problem. But I have EM's and experienced the same thing.
The solution was a re-tightening of the O2 sensors. One worked itself pretty loose.
Old Jan 5, 2006 | 11:13 PM
redvette6spd's Avatar
redvette6spd
Once you get these little bugs worked out you are really going to enjoy your car. I have the same mods you have and couldn't be happier you should have over 400Hp at the crank and close to 400TQ after a good tune
Old Jan 6, 2006 | 10:01 AM
JEFNLSA's Avatar
JEFNLSA
Default Update:
Ran a code scan last night and pulled that same ol' PO152 - .02 Sensor High Voltage. I know it's not the sensor cuz it's been replaced and the same code is still there. Car runs incredible and when hooked to a top-dollar scanner, that reads all the info, it shows AOK on everything. Baffling!
I've had that PO152 for about a year now and no matter what mods I've done - headers, Hotcam, new .02's., custom tune, full tune-up - the #$@!er still shows up!
Don't get me wrong, I'm lovin' the car BUT I'm this close to perfection and...
Old Jan 6, 2006 | 10:03 AM
Nathan Plemons
Can you just turn that code off?
Old Jan 6, 2006 | 10:06 AM
JEFNLSA's Avatar
JEFNLSA
Good question. If there's a way I'm all ears. My main & really only concern is passing emissions. I have until July to get my car code free.
Old Jan 6, 2006 | 10:10 AM
  #33
Red_Vette_93's Avatar
Red_Vette_93
Hey Jeff on your webpage the sound bite of the car, is that before or after you installed the headers?
Car looks Good
Old Jan 6, 2006 | 10:25 AM
  #34
Nathan Plemons
I know my ECM and many PCM's will allow you to just turn off reporting on certain codes. I guess the reasoning is that since the same PCM can be used in several different configurations you may or may not actually have the components. In some states all you need to do to pass emissions is to plug up a scan tool and have it report no codes. One way to do that is to eliminate the emissions related codes. That's kinda a cheap *** / cheating way of doing it, but it works! It just annoys me that the people with the OBDI computers can't do the same. An OBDI car with full emissions equipment can fail because it has to take a sniffer test while an OBDII car can pass without any emissions equipment simply because it doesn't set any codes. It's just not fair I tell you!
Old Jan 6, 2006 | 11:09 AM
  #35
JEFNLSA's Avatar
JEFNLSA
Car looks Good
Thx
That's an old clip before headers or hotcam. The pics are not up to date either. Time to redo...cam, headers, tires, rotors, shifter, spare tire delete & lowering etc.. all new
btw...Car sounds completely different now. Much better.
Old Jan 6, 2006 | 11:24 AM
  #36
JEFNLSA's Avatar
JEFNLSA
In some states all you need to do to pass emissions is to plug up a scan tool and have it report no codes. An OBDI car with full emissions equipment can fail because it has to take a sniffer test while an OBDII car can pass without any emissions equipment simply because it doesn't set any codes. It's just not fair I tell you!
I sympathize since I can't empathize...
That is how emissions works here in Phx. OBD2 just requires a code scan. That is how I am getting away w/ no cats (sorry Bogus ). Regardless, I still need to be code free so somehow I need to rid myself of this PO152. At this point and especially since the car runs so well I'd be all for erasing that from the PCM but how?
Old Jan 6, 2006 | 11:25 AM
  #37
Nathan Plemons
You'd have to have somebody who can program the PCM turn off those codes. Who did your tune?
To Post header install ????
Old Jan 6, 2006 | 11:30 AM
  #38
JEFNLSA's Avatar
JEFNLSA
Bryan @ pcmforless.com
Is this a simple thing that a local shop w/ Tunercat - kinda like LT1 Edit - could do for me? Otherwise, I need to send my pcm back to him.
Old Jan 6, 2006 | 12:44 PM
  #39
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
That would be great if that's all it is. It's freakin' embarassing...I spent alot of money on this upgrade and my car is poppin' & spittin' all over the place. I'll check it out after work. Thx...
Jeff , why don't you go with 2 R/T High flow cats this should help a bit ....I have them on my set up and there is very little popping from back presure and I have no muffs...good luck and congrats on the new set up !
Old Jan 6, 2006 | 12:48 PM
  #40
Nathan Plemons
Because even with high flow cats it is well documented that you can still set codes on the second set of O2 sensors. It may not solve his problem and it would cost more money. The only reason to do that would be if you wanted to be environmentally friendly, and who wants to do that (Bogus )
