4+3 Od
Good Luck,
Paul
I have troubleshot this problem before by connecting a wire to the transmission lead and then running the wire into the cockpit, connected a DVM, then drove the car.
If you have voltage at the transmission connector, use an ohmmeter to test the coil in the transmission. If the coil is open you will have to pull the pan and replace the coil. If you do, don't lose the check ball that goes in above the coil.
Good luck,
Have a great day,
OOOOBA
OOOOOO
If you get 12V at the side of the overdrive, then you're possibilities are a bad pressure switch, bad solenoid, pump sucking air due to dislodged filter or torn grommet... or bad overdrive unit.
I tested my pressure switch continuity by hooking it up to compressed air. It has some hysterisis, meaning it doesn't open and close at the same pressure, but that's fine.
Don't use ecklers grommets, they're cheap rubber and get soft and tear from the atf.
That external spade terminal passes the 12V signal into the overdrive case to a normally open pressure switch, then to the overdrive solenoid. (Normally open means the pressure switch only closes and sends the 12V thru to the solenoid if there's enough fluid pressure.)
The trans case is the ground side of the solenoid.
When the solenoid gets 12V across it, it forces a piston out to change the hydraulic path and activate the overdrive. Note, the solenoid will NOT do anything in diagnostic mode, because the fluid pressure switch isn't closing the circuit path. If you hear a clicking, it's the overdrive relay on the firewall, not the overdrive solenoid.
Anyhow, if you have 12V between the spade terminal and the case, the next step is to open up the overdrive unit and jumper the pressure switch to see if the solenoid plunger pops out in diagnostic mode. Its easy to observe if beforehand, you push the solenoid shut (by hand). DON'T use the solenoid any longer than necessary to test it with the pressure switch jumpered as it will overheat and damage the solenoid.
If the solenoid doesn't move with 12V across it, then it needs replacing.
If the solenoid plunger pops out, then either your pressure switch is bad or the overdrive pump isn't putting out enough pressure. Common causes for low pump pressure in order are:
low fluid level
cut or dislodged filter grommet
dislodged pickup tube or oring
mechanical failure in overdrive unit
Obviously test the pressure switch before you assume it's mechanical failure, I hooked mine up to a compressed air source and used a continuity meter. I don't remember what pressures it opened/closed at, but it's not like you can just blow into it.
And I have absolutely no idea where to find a replacement pressure switch or solenoid besides from another 4+3 transmission
This dash gets its coolant reading from a different sensor.
But, I think the ECM will throw a code if that sensors unhooked and ignore it.
If you try to turn on the overdrive below 140*, the dash indicator light won't come on. Dash light only comes on when the overdrive relay is activated by the computer and sending 12V to the trans.
low fluid level
I do, however, suspect that there must be a difference in some 4+3 units. Centralcoaster is talking about a solenoid in which you can see a plunger. My 88 has no such plunger. With the pan removed there was the pressure switch and a hockey puck shaped coil. It had no visible plunger. When the coil is removed there is a check ball above it that is actuated by the coil. On models with the coil like mine you just need to pull the pan and use an ohmmeter on the coil itself. If it is open it will need replacing. If it does indeed have continuity it is in all likelihood okay. At that point you would need to test the internal wiring and the pressure switch.
Thanks for the great explanation CentralCoaster. It sounds like insane is moving along well in the troubleshooting process.
Have a great day,
84, 176*
85, 140*
86, 122*
87, 122*
88, 122*
The u-joints went bad from someone replacing them and not putting in the correct u-joints. Parts, labor and tax cost $261.06 to have all four u-joints replaced.
Scorp508 - Thanks. I was wondering why my car went into overdrive when it was 142*
