LT4 HD Timing Chain Any Problems with them?
Old Jan 5, 2006 | 04:57 PM
tvetta's Avatar
tvetta
Default LT4 HD Timing Chain Any Problems with them?
I just spent a ton of money in a motor for my 94. I put an LT4 HD timing chain. I saw a post a while ago with a member having issues with one of the gears wearing prematurely and then I saw a guy selling a motor on ebay describing an issue with a gear on the same type of unit.
Anybody have any experience or know of GM any problems?
Old Jan 5, 2006 | 05:09 PM
LT4POWR's Avatar
LT4POWR
Old Jan 5, 2006 | 05:20 PM
sothpaw2's Avatar
sothpaw2
There were about 5 of us between here and Z28 forum whose motors were affected. I think 3 of us had to refurbish the whole motor. If you catch it early you can just clean out the oil pan & timing area & put a diff. set in.
I can't explain what's going on. Two leading theories are 1) some install gremlin 2) the water pump bearing is seizing up, causing the gear to wear way to much.
Most just change to an E pump. LT1 gear sets also don't have this issue.
Old Jan 5, 2006 | 06:54 PM
tvetta's Avatar
tvetta
I put in a new water pump so should I have no problems or is the timing chain causing the water pump bearing to sieze?
Old Jan 5, 2006 | 08:14 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
The water pump is not the issue.it is the tensil strength of the gears if I remember right.Not every one has problems but it is something if I were you to keep and eye on while you break it in.
Old Jan 6, 2006 | 05:43 AM
tvetta's Avatar
tvetta
I will keep an eye on it but has anyone ever approached General motors on this. If not, how does one do so?
They have to keep track of quality issues like this and have to provide corrective actions.
Old Jan 6, 2006 | 10:54 AM
tjwong's Avatar
tjwong
I have used 5 of them in the last couple of years and not a problem so far. I have one in my personal car and no issues yet.
Old Jan 6, 2006 | 11:28 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I think allot comes down to installation. The water pump gear, the two oil holes that "feed" the gears from the lifter valley(or is that three hole, three plugs). There was a lengthy discussion about a month ago, and there was allot of great ideas/thoughts that came up.
http://forums.corvetteforum.com/show....php?t=1251482
Old Jan 6, 2006 | 11:55 AM
sothpaw2's Avatar
sothpaw2
No, I put in a new GM OEM LT1 water pump in and my motor was destroyed.
The gears I have measured were soft, both new ones I ordered, a 1996 LT4 gear, and my failed gear. Since the 1996 LT4 set works for everyone and most do not even have a problem with the ED set, I am lead to believe that the LT4 & ED sets are crappy designs but they should still work, something else is pushing them over the line.
If you have this installed I would simply suggest watching your drain plug and also, cut your oil filter up every change to ensure that there is no metal being picked up-not even small shards, no trace.
Old Jan 6, 2006 | 11:57 AM
sothpaw2's Avatar
sothpaw2
Let me know if you know who the heck to approach at GM. I have not attempted it.
Old Jan 6, 2006 | 01:59 PM
tvetta's Avatar
tvetta
I have read the previous thread and I still don't know what the cause is!
No one is going to listen to you unless there is concrete proof.
My mechanic has installed some and has never had a problem with them and he said he has never heard of such a thing.
This guy eats and sleeps vettes and works for a dealership and his job is only working on vettes.
Old Jan 6, 2006 | 03:17 PM
Strick's Avatar
Strick
I think I remember reading about a batch of gears that were not hardened correctly. The problem is how do you know if you have one from that batch?
Old Jan 6, 2006 | 03:26 PM
steve40th's Avatar
steve40th
Get ahold of Cloyes I guess, as they make them.
Old Jan 6, 2006 | 03:44 PM
Tom Piper's Avatar
Tom Piper
It would be interesting to see that article.
If it is true and Cloyes is aware of it and Cloyes makes the ED timing set, I would think Cloyes would bend over backwards to correct it for those who can send them gears that aren't hardened correctly.
Tom Piper
Old Jan 6, 2006 | 05:46 PM
sothpaw2's Avatar
sothpaw2
If this was it, then I managed to find 3 gears including a 1996 OE LT4 gear which were not done right.
Any one have an ED cam gear out of the motor with 25-30 k mi on it that I can test? If it's harder and it works, then that's the story.
Old Jan 6, 2006 | 06:07 PM
tvetta's Avatar
tvetta
Tom Piper
If Cloyes is aware of this then this a major product liability issue.
Sending me a new gear that cost them $10 doesn't cut it. I have $5000 in a motor plus installation. IF this has been identified then when were changes implemented? What was there recall procedure.
Heck to change out this gear alone will be $600 at least from a garage.
Then there are those that lost total motors.
Old Jan 6, 2006 | 06:11 PM
steve40th's Avatar
steve40th
Sending me a new gear that cost them $10 doesn't cut. I have $5000 in a motor plus installation. IF this has been identified then when were changes implemented? What was there recall procedure.
If proven a gear ruined your engine, big IF, they have insurance I am sure. Years ago a friend had a March Underdrive pulley come apart(jammed under remaining part of pulley, locked motor bent valves etc etc), and after finding out the recall notice never got to him, he was awarded a new GM crate LT1 with installation. That is really rare though. Very rare.
Old Jan 7, 2006 | 05:01 AM
tvetta's Avatar
tvetta
I am just going to have to get a hold of someone at Cloyes next week.
I just need some assurances that if there was an issue it was identified and resolved.
To LT4 HD Timing Chain Any Problems with them?
