Knock Sensor Resistance
Old Aug 4, 2001 | 09:49 AM
NHVett's Avatar
NHVett
Cruise-In I Veteran
Cruise-In II Veteran
Default Knock Sensor Resistance
My knock sensor is new, and reads 300 K Ohms on a good quality DVM. Anyone know if that is normal for an 85 Knock Sensor?
I'm having all kinds of timing problems and am looking at all related possibilities. This condition has existed since the engine rebuild.
[Modified by NHVett, 7:50 AM 8/4/2001]
Old Aug 4, 2001 | 10:52 AM
SouthernSon's Avatar
SouthernSon
Default Re: Knock Sensor Resistance (NHVett)
Did you torque the sensors more than 15 #/ft. If torqued more they will not work correctly.
Old Aug 4, 2001 | 03:29 PM
NHVett's Avatar
NHVett
Cruise-In I Veteran
Default Knocking at Sensor's Door
Yep, betcha that's wot eye did. Crapola!
[Modified by NHVett, 1:29 PM 8/4/2001]
Old Aug 4, 2001 | 04:22 PM
hi-tek-vette's Avatar
hi-tek-vette
Default Re: Knocking at Sensor's Door (NHVett)
the sensor is probably way to tight ......sensor should read 9.5 to 10 vcolts @ no detonation, less than 1 volt means it is sensing detonation, or is damaged
Old Aug 4, 2001 | 04:24 PM
hi-tek-vette
by the way, do you see a code # 43 ??? thats set by detonation ........ or the sensor thinking so .......
Old Aug 4, 2001 | 09:26 PM
vettenuts's Avatar
vettenuts
Don't know about 85, but a 90 should read 3,300 to 4,500 ohms from sensor terminal to ground. I imagine 85 would be of similar values such that 300 ohm may be indicating a problem. I would remove and check resistance between pin and housing. If still 300, you may have damaged it during installation.
Old Aug 4, 2001 | 10:24 PM
cohocarl's Avatar
cohocarl
I printed out a thread from over ago (Just found it) that recommended a 4.5k to 5k ohm 1/4 watt resistor to bypass the knock sensor on an 85. I just got back from Radio Shack with a pack of 4.7k ohm resistors, soldered a couple leads to one and "replaced" my knock sensor with it. I just got done with an engine swap in my 85, and I think I may have whacked the side of the sensor when I was lowering the motor into it's mounts, and was unsure of it's operation. I just got back from a quick ride and it seems to be crisper (if you know what I mean). No check engine light. I got on it a couple times after I got all the fluids warm and I didn't hear any spark knock either. I had a 68 camaro with 10.5/1 ratio, so I know what spark knock is. Will play with the Gtech tomorrow....wife getting a little annoyed......
Later,
Carl :yesnod:
Old Apr 2, 2024 | 05:19 PM
hretter's Avatar
hretter
That's what I did, too - overtorqued it. I backed it out, retorqued to 14 lb ft and no water leak at the sensor and code 43 went away. Thanks.
Old Apr 2, 2024 | 07:04 PM
AmoriFati's Avatar
AmoriFati
I used teflon tape and then torqued it. Not sure if it did what it was supposed to do, to minimize false knock.
Old Apr 3, 2024 | 02:19 PM
Tunedport90's Avatar
Tunedport90
85-89 is 100k ohm ks
Old Apr 3, 2024 | 02:54 PM
AZSP33D's Avatar
AZSP33D
Problem is that the pipe thread is not deep enough to engage the KS more than 50% so people apply more torque... especially since this has coolant behind it, so none of us want it to back out or leak coolant. Best solution is to chase the threads with the 1/8 NPT tap (I think that's what it is) either at overhaul or with grease to try to trap the metal bits from invading your cooling system, and then install with a light coating of teflon Pipe Dope. Teflon tape is nicer to clean up and remove, but it's not as good of a seal for 20psi of coolant or steam.
Old Aug 27, 2025 | 10:46 PM
DJJ123's Avatar
DJJ123
I understand that this thread is quite old but I’ve been dealing with some pinging and when i tested my sensor on my 86 i got 166kohms. Would you happen to know if that’s an acceptable value?
Old Aug 27, 2025 | 10:47 PM
Tunedport90
Tpi maf is 100k sd 90-91 is 3.9k
Old Aug 27, 2025 | 10:48 PM
DJJ123's Avatar
DJJ123
Much appreciated dude
Looks like it’s about time i replace it…
Old Aug 28, 2025 | 02:17 PM
hretter's Avatar
hretter
I just measured a new knock sensor on my '86 C4 and it's 99.9klohms. FYI, when it started pinging, it turned out to be a blown head gasket. I found it using the radiator fume testing method. Good luck.
Old Aug 28, 2025 | 02:53 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
The internal 100k resistor in the early sensors is just there to bleed off voltage occurring during shipping and handling/installation. The ESC module then has an internal 1.5k (IIRC) resistor to set the knock signal input impedance. It sounds like your sensor resistor has broken or degraded, but regardless, I wouldn't expect that 166k reading to be the problem issue.
FWIW, the harness connector (on several model years) was made with some soft conductive metal coating to conform to the sensor terminal for a good low-resistance connection to the sensor. The downside of this is that the harness connector has a limited ability to survive much much more than a handful of connections and disconnections. If your connector has intermittent continuity, that can make the ESC module think that there is knock going on when there actually isn't any.
Keep us updated on what you find out.
To Knock Sensor Resistance
