Exhaust Manifold Covers?
Old Jan 8, 2006 | 04:33 PM
L98tech's Avatar
L98tech
Default Exhaust Manifold Covers?
I've heard of alot of people taking their covers off. Whats the point? It only makes them look like shorties, which they basically are. Someone let me know........................
Old Jan 8, 2006 | 05:16 PM
Biff Buyer's Avatar
Biff Buyer
because they rust and look like crap. Then they rattle to hell.
Old Jan 8, 2006 | 05:33 PM
rightofway's Avatar
rightofway
i've seen that some people polish them a little and they come out looking nice and clean. seems like taking them out would increase underhood temps
Old Jan 8, 2006 | 09:44 PM
John A. Marker's Avatar
John A. Marker
Default Clearance
I put AFR 180 heads on my 85 and had problems with plug clearance. The plug wire boots were also resting on the shields with the new heads (fine with stock). I removed these heat shields (PITA) and had enough clearance to get a plug socket on the plugs and the boots had good clearance.
Old Jan 9, 2006 | 01:11 AM
kopbet89c4's Avatar
kopbet89c4
How many bolts are holding these suckers in place? If I run out of patience, I might just whip out the oxyacetylene torch.
Old Jan 9, 2006 | 03:24 AM
VtVette's Avatar
VtVette
Old Jan 9, 2006 | 06:44 PM
Davemc1963-87conv's Avatar
Davemc1963-87conv
I've got mine off at the moment and was going to paint them with Silver Very High Temp spray paint.
I've shot blasted the manifolds, but don't intend to paint them as well. I expect they will get discoloured and crusty eventually though just like before. I will be using new sheet metal screws to refit the covers as well. I'm still debating whether to give the aluminised covers a quick shot blast as well before painting them, or just rub the crusty bits with emery cloth.
If they turn out cheap looking, I might not refit them, have to see how they turn out.
Old Jan 10, 2006 | 12:47 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I removed the shields on my 86 and I polished the rusty exhaust manifold with Mid Americas exhaust manifold dressing,similair to Callyx or whatever theyre spelled.Look brand spanking new when done!Shiny as ever!
Basically you brush this metallic looking paste onto the manifolds and rub it off with a cloth.They stay looking shiny for months.If it needs to be redone,then brush some on and rub it off.Works very very well.
Turned my rusty looking shorties into brand new polished looking shorty manifolds.
Old Jan 10, 2006 | 01:16 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Because the heat shields look like ****.
Old Jan 10, 2006 | 01:31 AM
86PACER's Avatar
86PACER
Heck yes they do. So does the inside of the ports.
Old Jan 10, 2006 | 02:28 PM
TM-Z06's Avatar
TM-Z06
CentralCoaster - those cleaned up nicely. Too bad the LT1/4 manifolds don't look like that.
Old Jan 10, 2006 | 08:45 PM
John A. Marker
To get the shields off, you have to remove the exhaust manifolds! DAMN
Old Jan 10, 2006 | 09:15 PM
CentralCoaster
You pretty much have to remove em anyways to paint them, and defintely to clean up the ports.
You could remove the heatshields with headers on the car, but you'd have to destroy the inside one to fish it out. Thatd be a non-reversible mod (although replacements would be easy to come by.
Old Jan 11, 2006 | 03:30 PM
Supernatural's Avatar
Supernatural
I took the heats sheilds off the manifolds from my '88. I had the A.I.R. tubes cut off and welded up. Then I used a dremel to grind down the inside ports and then Painted the manifolds with high temp black paint. It Frees up more room under the hood around the spark plugs and it Definiately looks better.
Old Jan 11, 2006 | 03:34 PM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
I would like to see a picture of that. Bet it looks good!
Old Jan 11, 2006 | 05:45 PM
TM-Z06's Avatar
TM-Z06
If I had an L98 I take the stockers off, remove the heat sheilds and send them off to be extrude honed (http://www.gethoned.com/your_parts.html). They would probably flow better than most aftermarket short-tube headers and cost less.
To Exhaust Manifold Covers?
