EGR Temperature Switch
Old Aug 4, 2001 | 08:23 PM
CG77VETTE's Avatar
CG77VETTE
Default EGR Temperature Switch
Can someone give me some advice as to how to reach the connector for the EGR temperature switch? I can see it behind the distributor but how do you get to it? I can't even touch it with the tip of my finger! I think I can reach it if I take the distributor cap off but I don't want to go through that if I don't have to. Thanks in advance for any help.
Old Aug 4, 2001 | 10:27 PM
JIM FL's Avatar
JIM FL
Default Re: EGR Temperature Switch (CG77VETTE)
I HAD THE SAME PROBLEM. I CUT THE WIRE BACK APPROX 2" FROM THE SWITCH AND INSTALLED THE NEW SWITCH AND SPLICED THE WIRES TOGETHER. COVERED WITH SHRINK TUBEING IT LOOKS OK. NO MORE CODE 32.
Old Aug 5, 2001 | 12:42 AM
moffitt's Avatar
moffitt
It's easier with the distributor cap removed.
But not much!
To EGR Temperature Switch
