Hooker Headers Question
Old Jan 10, 2006 | 12:33 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default Hooker Headers Question
I bought a 94 LT-1 Coupe in May 05. The seller tells me it has hooker headers (Super Comps). I look under the hood and afirmative, those are Hooker Super Comps. I don't really think twice about it as I know the car is a bit of a project and it sounds so good.
I climb under the car a few months ago and discover that the headers are within fractions of an inch of actually touching the oil filter under the car! I assume that it is not a great thing that they are touching the oil filter. I will take a guess on this on and say that these headers are probably not designed for the corvette. Maybe they fit F bodies?
Anybody else run into this before? I was preparing to take them off and send to Jet Hot for a coating... I don't want to spend a bunch of money coating these if they are the wrong fit.
Old Jan 10, 2006 | 12:44 AM
mike43725's Avatar
mike43725
more than likely the headers you have are probaly just for the first generation sb chevy, so they would probaly fit the l98 engine with no problem, i have hedman headers and there for my 85 corvette, but if you compare them to just any sb 350 headers they are pretty much the same, so i guess what im saying is that mabey there not designed for the lt1
Old Jan 10, 2006 | 12:46 AM
thirdtimevetteowner's Avatar
thirdtimevetteowner
How much do you want for em?
Rich K
Old Jan 10, 2006 | 12:51 AM
vader86's Avatar
vader86
I wouldnt worry about it.
Old Jan 10, 2006 | 01:28 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
The Hookers on my l98 are miles away from the oil filter. The LT1 may be different but I would'nt think they should be touching it.
That being said, if they are not quite touching it and it can still be removed for filter changes, and if you are having them coated then it will cool'em and you should be ok.
Old Jan 10, 2006 | 01:56 AM
AZC4Guy's Avatar
AZC4Guy
IMHO, there's nothing to worry about if you have them coated.
Old Jan 10, 2006 | 11:25 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I have the Hookers 2151s on my LT-1. There is no problems with them being so close to the oil filter. Mine are coated. If you are really worried about it you could put some header wrap around the spot next to the oil filter.
Old Jan 10, 2006 | 11:50 AM
CFI-EFI's Avatar
CFI-EFI
If you think about it for a second, you can answer your own question. The heads bolt to the block. The headers bolt to the heads. The oil filter bolts to the block. The header to oil filter clearance wouldn't be any different if it were in a Camaro, Nova, pick up truck, or an engine stand. Your headers MAY deviate from the "model" but the problem isn't because they are in the wrong chassis.
RACE ON!!!
Old Jan 10, 2006 | 12:44 PM
Nathan Plemons's Avatar
Nathan Plemons
These are Hooker 2151's on my LT1 as you can see there are no problems with oil filter clearance.
Old Jan 10, 2006 | 02:58 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
Here's a pic of mine also. They are a little close but nothing to worry about. If yours are touching then you have something else wrong.
Old Jan 10, 2006 | 08:43 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default That looks like my fit
VictorRussell'92
That looks like my set up. Mne are not actually touching but dang close like yours. Will pull them off shortly and sent to JEt-Hot.
Old Jan 11, 2006 | 10:29 AM
VR'92's Avatar
VR'92
St. Jude Donor '03
Originally Posted by jakers
VictorRussell'92
That will solve any issues you may be having from it. It's pretty doubtful that its is causing any real issues though. Good luck.
To Hooker Headers Question
