Boost fan
Old Jan 10, 2006 | 02:15 AM
Dave-B's Avatar
Dave-B
Default Boost fan
On my 86 Z51, when should my rad. boost fan come on???
Old Jan 10, 2006 | 09:03 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
around 238
Old Jan 10, 2006 | 10:13 AM
rick lambert's Avatar
rick lambert
IF its a stock temp switch in there. But if someone put in a lower temp switch it will come on at a lower temp.
Old Jan 10, 2006 | 10:27 AM
Dave-B's Avatar
Dave-B
Thanks guys, I knew that was an easy one for the forum. I've only had the Z51 for about 5 mounths, and have not seen that kind of temps. These cars are so much different than the old carb cars, but I'm learning. Thanks again. Dave
Old Jan 10, 2006 | 11:02 AM
CFI-EFI's Avatar
CFI-EFI
A quick test of the fan, would be to pull the wire off of the aux fan switch, between the #1 and #3 spark plugs in your left (drivers) side cylinder head, and ground it. If it and the relay are OK, the fan will run with the ignition on.
RACE ON!!!
To Boost fan
