Coolant sensor on passenger head
Someone know the AC Delco or GM part#??
If someone knows also the part# of the connector ... :o
It seems simple to found it for models up to 89...not for a 90-91
Thanks in advance.
-Beppe-
They are all pretty much the same (SBC)-You can cross reference that # if you are looking for the ACDelco one
Edit:This is the one between #6 and #8 cyls withthe spade connector, right?
I can find these sensors (for 89 and earlier) not for 90-91 models.
My sensor (the one installed now in my car...and i don't know if it's the original of a 90) has a mushroom end.
I'm pretty sure that if I buy a 89-earlier sensor/connector it will be the same... but I'm afraid about the lower and max voltage used by the chip to translate the volts in °F.
Why 90 and 91 models haves always different parts....???
-Beppe-
-Beppe-
...the only thing I know is that before reprogramming my chip with lower temp starting fans, the fans started at a stock (high) temp (both fans...)
-Beppe-
Someone else on the Forum is having a similar problem, trying to identify the sender/switch he was sold. He posted a photo of what he bought. Based on what you posted, I believe it's the same one you're looking to replace. BTW he also posted a photo of the box with the part number.
Check it out, may solve your problem. If I locate the post, I'll post the link.
Hope this helps.
Jake
Let me know if it's the one you're talking about.
http://forums.corvetteforum.com/show...32&forum_id=48
Hope this helps.
Jake
-Beppe-
This part should be available. Not sure if the LT1's have the same sending unit on the passenger side. The 90 and 91 should be the same.
Let us know.
Spent some time working out of Brindisi. Bonjarno.
dlmeyers 90 coupe zf6 3pseed shocks
Hope this helps.
Jake
-Beppe-
Let us know.
I have 2 temp cooling sensors.
One is located under the throttle body (and someone in this forum said that this sensor is to measure the temp of the coolant and send this measurement to the gauge in the dash.)
Occasionally I had this sensor (the one under the TB) disconnected and I had a LOWER temp reading in the gauge (but not zero..just 50 or 60 °F less than the real temp).
The other sensor is the one on the pass side head (and someone in this forum said that this sensor is to measure the temp of the coolant and send this measurement to the computer to tell him if is the moment or not to activate the fan(s) )
No others temp sensors on my car...
the only one additional is the one under the plenum (intake air temperature) that seems equal (really equal !) to the one under the Throtle body described above as coolant sensor..
Can someone confirm that the function I explained are right??
-Beppe-
Also the one under the plenum for the air temp and the one in the front of the manifold are the same sensor. I had to buy a pigtail adapter for the one in the plenum though because the plug end didn't match the original wiring harness. I got this from www.oreillyauto.com , came with sensor and pigtail. I walked into the store and I know the guy behind the counter and told him my problem, he just chuckled, and got the sensor that came with the adapter, which he said gm made a change to the plugs sometime back then and when you buy the new air sensor, if you have the old plug, you have to get the one that comes with the adapter pigtail. Yes its more money for the one with the adapter of course.
Chris
RACE ON!!!
-Beppe-
Jake
RACE ON!!!
But, what you are saying is just the opposite me and hz900 are supposing.
I have to try to see if I disconnect the cable from the sensor on the head, the temp on the gauge will fall or not. if I'll se a decrease on temp reading on the gauge you are right.
-Beppe-
-Beppe-
RACE ON!!!
