Need Shock absorber installation advise
Old Jan 12, 2006 | 07:43 PM
ceberus's Avatar
ceberus
Default Need Shock absorber installation advise
I ordered a new set of Bilsteins from eshocks.com and I will be installing them tomorrow. Any tips or tricks that I should know? This is my first time doing shocks on any car. Thanks....
Old Jan 12, 2006 | 08:12 PM
MYCoupe's Avatar
MYCoupe
Very straight forward job. For the fronts you don't even need to remove the wheels or jack up the car. The rears will need to remove the wheels, but overall an easy job. Since it's your first time i'd say 2-3 hours.
Old Jan 12, 2006 | 09:35 PM
ceberus's Avatar
ceberus
Thanks!
Old Jan 12, 2006 | 11:30 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
It will be easier to install the fronts if you jack up the front of the Vette some.
Old Jan 13, 2006 | 12:28 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I jacked my car.
Also, (unless you're stronger than me) you can't pull/push the shafts on Bilsteins like you can with less expensive shocks. I put a block of wood under the rotor and lowered the car to get the shock to feed into the hole. (You'll see what I mean).
Finally, don't miss out on the fact there is a hex cutout in the tip of the shaft. You can use a hex key to hold it from rotating while you install the top nut.
If you've done shocks before, you won't have any problem!
Old Jan 13, 2006 | 07:26 AM
runner140*'s Avatar
runner140*
Straight forward job, no tricks. Took me 3 hours from start to finish but I am a slow wrench turner.
Old Jan 13, 2006 | 10:17 AM
ZumZum's Avatar
ZumZum
At the rear shocks, use some liquid wrench or whatever on the top mounting plate bolts. You do not want to twist/snap one of them off.
Old Feb 8, 2006 | 02:13 PM
ThePizzaC5's Avatar
ThePizzaC5
Are there any picture write-ups on this? I've done plenty of macpherson swaps, but never this. Thanks to whomever.
Old Feb 8, 2006 | 02:14 PM
ThePizzaC5's Avatar
ThePizzaC5
D'oh - wrong year. Hopefully a C5 owner can help me out.
Old Feb 8, 2006 | 02:26 PM
03whitecoupe's Avatar
03whitecoupe
http://www.c4guru.com/articles/Insta...rontShocks.pdf
Old Feb 8, 2006 | 02:51 PM
ThePizzaC5's Avatar
ThePizzaC5
That was fast - thanks! Considering the end of the C6 Z06 shock looks pretty much like that, I'm gonna go ahead and presume that they're similar or pretty much, the same.
To Need Shock absorber installation advise
