LT1 Timing Chain Durability
Old Jan 12, 2006 | 09:01 PM
mich_93's Avatar
mich_93
7th Gear
Default LT1 Timing Chain Durability
I have a '93 6-speed coupe, and was planning a top-end engine upgrade this winter. Below are a list of the planned modifications:
- LT4 Hotcam with 1.6 roller rockers (.525" lift) or 1.7 roller rockers(.558" lift)
- Precison Porting Stage 3 head package & ported intake
- Comp 918 beehive spring
- 6200-6400erpm redline
- EM longtube headers
I currently have the cam driven water pump and not vented opti. I had originally not planned to upgrade these components, and was just going to just replace the stock timing chain with a GM OEM part. Will the stock LT1 timing chain survive with these planned modifications, or should I consider upgrading to something better? I want to keep the cost down, but want to make sure it is durable as well. The car is primarily used on the street and a couple open track days (roadracing) a year. Thanks
Old Jan 12, 2006 | 09:06 PM
SPEED750's Avatar
SPEED750
I bought the lunati timing set from summit for $109. You can also buy a vent kit for your opti for $20 from ecklers.
Old Jan 12, 2006 | 09:39 PM
bobmic93's Avatar
bobmic93
Im going through these same mods on my 93 and Im taking no chances. Vented opti, water pump, Extreme Duty timming chain and cover. All GM parts for around $750 Youd be crazy not to do while all these components are already off. Its kinda of like insurance and peace of mind.
Old Jan 12, 2006 | 09:45 PM
Darkgh0st's Avatar
Darkgh0st
I had done last summer except for the headers, you wont be dissapointed. The only thing I would suggest is to leave the rev. limiter the same
Old Jan 12, 2006 | 09:50 PM
bobmic93's Avatar
bobmic93
Why? Where should it be set at?
Old Jan 12, 2006 | 09:55 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Your top end combination is virtually identical to mine. Should you decide to go with 1.7 rockers, make sure and check piston to valve clearance very carefully. Also have Bob cut the spring seats down a little so you can set those springs at optimum installed height for your combo.
Old Jan 12, 2006 | 10:16 PM
Darkgh0st's Avatar
Darkgh0st
My mechanic kept my rev limiter at it's stock value and told me that I should keep it there. I didnt get the full explaination but I trust him. My understanding is that the hotcam and upgraded spring setup will hold up to the higher revs, but it's not enough of a gain to justify it.
Old Jan 12, 2006 | 10:21 PM
Corvette Kid
You'll probably make peak HP around 6200, mine did anyway. May as well set it at least that high. BTW, I don't like the stock chain or the ED, double rollers are just too superior.
Old Jan 13, 2006 | 12:51 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Stock Opti rotors do not like spinning above 6200 very much.Pooof.Probably why your Mechanic said leave it alone.I would say by no means set it higher than that.
Old Jan 13, 2006 | 03:59 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Not to hijack, but was there a bunch of slack in the Lunati Tining Chain, as in the stock LT1 chain? Or was the Lunati set up tight as a regular double roller chain?
TIA
Old Jan 13, 2006 | 05:48 AM
93 ragtop's Avatar
93 ragtop
You know, I would like to say you are crazy, but my car runs better letting it shift on its own around the 5700-5800 setting. I have tried holding it to 6000-6200 and it actually runs a little slower at the track. Im still running stock injectors which I always figured was the reason for this. They are maxed out and are still going lean on top end.
Old Jan 13, 2006 | 07:50 AM
Bruce's Avatar
Bruce
When I had head/cam/header on my 93 6 speed. I was running LPE219 cam with 1.6rr. 219/219 @ .05 .560/.560. I was still using stock LT1 chain but it were brand new one. I raced at the track and street and often take it up to 6500rpm no problem what so ever. But I feel much safer to replace with double chain or extreme energy chain.
Old Jan 13, 2006 | 08:22 AM
sothpaw2's Avatar
sothpaw2
I would NOT recommend the ED chain set. Several of us have had issues with them which, if gone undiagnosed, ruin the whole engine (require the motor be pulled, disassembled, cleaned...)The LT1 chain will be adequate for a while, but of course you should put in a new chain. I also would set my rev limiter at 6200 or 6300 with the LT1 chain, and when on the road course, keep it conservative, ie, below 6000 rpm.
You must also at least get some 28# injectors if you push it on the road course. The duty cycle with the stockers is ok for drag racing, ie short bursts, but sustained high rpm operation with the new heads/cam is just too much.
If you like the idea of an electric waterpump, then of course you can go to a better chain with that.
Old Jan 13, 2006 | 11:42 AM
mich_93's Avatar
mich_93
7th Gear
I have always been a bit relucant to use an electric water pump, although I don't have a real good reason why. I like the idea of having a mechanical connection spinning the pump, but it sounds most people with the electric pump have been happy with them. Anyone had any issues with the electric water pump?
Old Jan 13, 2006 | 11:51 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I like my Meziere electric pump. I also went with the a new cloyes 3145 double roller timing set. Its cheap if you do the electric pump.
Old Jan 13, 2006 | 11:57 AM
sothpaw2's Avatar
sothpaw2
Reliability of the relay & assoc. wiring is the real issue with the electric. If you use good quality components and weather pack connectors, keeping in mind that you don't want corrosion, then it should be no problem. But keep in mind that an electric pump is really a custom mod, everybody wire's them different & puts the relay in a different place.
I'll add that with regard to heads & cam, it is a wonderful seat-of-the pants gain in hp& tq. The downside though is the expense, and as I can attest, if something happens to the car, insur. companies don't want to give you anything for all that work& perforamance.
Old Jan 13, 2006 | 12:09 PM
Lichen's Avatar
Lichen
Exactly what I did a couple of months ago on my '93.
To LT1 Timing Chain Durability
Old Jan 13, 2006 | 01:17 PM
TM-Z06's Avatar
TM-Z06
Only I used the cloyes 3157 chain which is an extremely thick single roller that was built for LTx/electric water pump
Old Jan 13, 2006 | 01:54 PM
Hotred94's Avatar
Hotred94
The GM Hot Cam instalation instruction sheet says, "A heavy duty timing chain set is mandatory for engine operation above 5500 rpm." I used a Cloyes 3145 with an electric water pump. I've been very pleased with the way it turned out.
Old Jan 13, 2006 | 02:38 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
This is a good option too. With the 3145 you have to use different cam retention bolts with a thinner bolt head than the factory ones. This is simple and cheap but you wouldn't have to do that with the 3157.
