Static/dynamic compression, quench space are all things Im not up to par on and I will have to rely on my porter( Phil from Advanced Induction and my installer from LS1 Speed INC. ) Both have good reputations in the industry. But on this issue there on different pages. I have confidence in Phil(porter) knowledge on the topic butt my decesion will be 90% influenced from you guys. My time is running out. Which ratio would you shoot for? 50,000 miles and I always run 93 octane with 160 stat. Thanks fellas
I am going to go against the grain and say"don't do it". You are talking 1/2 point of compression.
"If" a full point is worth a true 3%. We are talking about 6 horse power, assuming a 400 hp motor. Even if we are talking 500 horses, 7 1/2 hp possibility does not seem, to me, worth the possible problems. .
after thinking about this for awhile,
it is not clear to me that high compression
is even desireable.
consider this thought experiment...
the same fuel is used, say pump93, or whatever
smog is not an issue
spark advance can be set as needed
Case 1, goal is max power at WOT at some high, but reasonable RPM.
Case 2, goal is improved efficiency at part throttle,
some loss of max WOT power is acceptable
I would think this might be possible,
going from case 1 to case 2, the engine designer
would increase the CR, to get more efficiency at part throttle, then at WOT, being forrced to back off
of the spark advance to get knock under control,
resulting in less WOT power than in case 1.
meaning, possibly, if something came from the factory,
optimised for part throtle efficiency, you
would not even want higher CR.
I know that I put 87 octane gas when I went to race on the 1/8th mile dragstrip. I ran an 8.8 @ 84 mph. The next time I went to the strip, I used 93 octane gas and I ran a 9.1 @ 82 mph. That is on the stock timing of 6 degrees BTDC, same chip that Alvin burnt me. Strange how higher octane gas made my car run slower. When I did a WOT scan, I noticed only 3 knock counts on 87 octane gas and 2 knock counts on 93 octane premium gas.
What would make my car perform better with 87 octane?
Octane slows down the burn. It is helpful to a point. Too much octane slows the burn too much. It is almost like taking too much timing away. I have had similar dragstip results when my car was stock. 110 octane slowed down my car quite a bit when the compression was 10.4 to 1
You folks are putting far too much thought into this...compression is free horsepower...not running as much as possible (for the gas) is like leaving HP on the table.
Read any high performance book/magazine and this is one of the basics. Why reinvent the wheel???
Why would 87 run better than 93 octane...probably because the air was not as good or the launch was not as good or your trans is going south or countless other items. Two runs do not make a good 'sample.'
I shall repeat my runs, but in the reverse order. I still did 3/10s better and was 2 mph faster in the 1/8th mile with the 87 octane.
